Far-apart double slit experiment
whoperj
What if:
1)
we put a swtich gate on the bottom slit. The bottom slit is normally closed, but we time it so we open it just before a photon/electron MAY arrive.
so far this will yeild the same result as traditional experiment?
2)
usually the two slits are close by, but we move it very far apart.
Let say a photon/electron goes through the top slit.
It takes 1 second for photon to go from the emitter to the 1st slit.
It takes 20 seconds for this photon to reach the center back wall.
It takes 10 seconds for this photon to reach the top section of back wall, because top wall is closer to center wall.
Total travel time is 11 seconds for the photon that went through top slit, and hit the top end of the back wall.
Now bottom slit has to be so far apart such that : the distance from emitter to bottom slit to top end of back wall is so great, even light cannot cover that much distance in 11 seconds.
3)
Quantum theory would predict interference pattern because the distance and travel time plays no part. This is the same traditional experiment.
Let say quantum theory is wrong. The gate is opened just before a photon MAY arrive. This information has to be conveyed to the photon that went through the top slit. Assume this information travels at the speed of light, then it cannot reach the photon that hit the top wall. So no interference pattern in the top end, maybe interference in the middle section...
Has a test been done to test a similar idea?
I know my test probably cannot be done because the slits have to be so far away, hardly anything hit anywhere...
Yes, a similar test has been done. Researchers have conducted experiments to explore the effects of introducing additional time and/or distance-based delays between the two slits in Young's double slit experiment. The results have shown that it is possible to observe interference patterns even when there is a large distance or temporal delay between the two slits. This suggests that it is possible to observe interference even when there is no direct causal connection between the two slits, indicating that quantum mechanics may not be based on classical causality.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
