Fast Fourier Transform in excel
The discussion centers on performing a Fast Fourier Transform (FFT) in Excel without a constant sampling rate. The user is struggling to fill the frequency column due to irregular time intervals in their data. Suggestions include following a specific online guide for FFT in Excel and noting that the frequency column requires an equation that assumes a constant sampling rate. To address the issue, it is recommended to adjust the time intervals by expanding the rows to ensure they are equally spaced at 0.5E-8 seconds, allowing for interpolation of the data. An attachment with a starter spreadsheet is also provided to assist with the process.
lavster
I really need your help - i can't work out how to do a FFT in excel. The main problem is I don't have a constant sampling rate - I recorded the time and then the corresponding magnitude of the wave. I have followed everything oneline but I can't seem to get anything to work as I can't fill the frequency column. Can someone help please? I've attached my spreadsheet. The first column is the time, the second is the data taken at that time and the other stuff is using the Data Analysis tool in excel
Thanks
thats what I was following. It only works for a constant sampling rate...
It's a bit of work but if you look at the delta t's it's always a multitude of 0.5E-8.
So expand the rows until all are equally separated by a t= 0.5E-8 and intrapolate.
Edit: see attached for starters
