How do I turn on model physics in MCNP6 to solve a fatal error?
In summary: The message should be. "Hey dumbass, you forgot to turn physics on. You might want to do that."In summary, the conversation was about a user seeking help with running MCNP6 code and encountering a fatal error. The problem was due to physics models being disabled and an isotope without tables being encountered. The solution was to use the OMIT block to specify which ZAIDs to skip and to use the MPHYS card to turn on model physics.
muthboravy
Hello everyone here,
I do need your help in this matter, please kindly help me solve this problem. I am new to this forum and now am seeking for help.
I am new to MCNP code, and I run MCNP6 code using BURN card and it give me fatal error say "Model required. Cannot use memory reduction option".
the whole input are below
C FUEL ASSEMBLY 17x17
C ==== fuel, Universe 1 =====================
1 1 -10.176 -1 u=1 vol=105.30977 imp:n=1
3 2 -6.56 1 -3 u=1 imp:n=1
4 3 -0.998207 3 u=1 imp:n=1
c ===== Guide Tube Uinverse 4================
6 3 -0.998207 -10 u=4 imp:n=1
7 2 -6.56 10 -11 u=4 imp:n=1
8 3 -0.998207 11 u=4 imp:n=1
c ===== Instructmentation Tube Universe 5====
10 3 -0.998207 -10 u=5 imp:n=1
11 2 -6.56 10 -11 u=5 imp:n=1
12 3 -0.998207 11 u=5 imp:n=1
c ========= SLOBA 15% Universe 3=============
13 5 -3.52 -50 u=3 vol=25.13274 imp:n=1
14 6 -0.001205 50 -51 u=3 vol=60.88407 imp:n=1
15 2 -6.56 51 -52 u=3 vol=4.712389 imp:n=1
16 5 -3.52 52 -53 u=3 vol=14.89115 imp:n=1
17 6 -0.001205 53 -54 u=3 vol=11.42193 imp:n=1
18 2 -6.56 54 -55 u=3 vol=25.31963 imp:n=1
19 3 -0.99827 55 u=3 vol=176.3183586 imp:n=1
c ===== Lattice Assembly ====================
100 3 -0.998207 -12 13 -14 15 4 -5 u=10 lat=1 imp:n=1 &
fill=-8:8 -8:8 0:0 &
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 & $ 1
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 & $ 2
1 1 3 1 1 4 1 1 4 1 1 4 1 1 3 1 1 & $ 3
1 1 1 4 1 1 1 1 1 1 1 1 1 4 1 1 1 & $ 4
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 & $ 5
1 1 4 1 1 4 1 1 4 1 1 4 1 1 4 1 1 & $ 6
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 & $ 7
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 & $ 8
1 1 4 1 1 4 1 1 5 1 1 4 1 1 4 1 1 & $ 9
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 & $ 10
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 & $ 11
1 1 4 1 1 4 1 1 4 1 1 4 1 1 4 1 1 & $ 12
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 & $ 13
1 1 1 4 1 1 1 1 1 1 1 1 1 4 1 1 1 & $ 14
1 1 3 1 1 4 1 1 4 1 1 4 1 1 3 1 1 & $ 15
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 & $ 16
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 $ 17
101 3 -0.998207 -16 17 -18 19 4 -5 fill=10 imp:n=1
102 2 -6.56 -20 21 -22 23 4 -5 #101 imp:n=1
103 0 20:-21:22:-23:-4:5 imp:n=0
c ========= Fuel Pin ==========
c /////surface card//////
c ======fuel pin======
1 cz 0.4095
2 cz 0.4175
3 cz 0.4750
c ===surface===
*4 pz -100
*5 pz 100
C =========guide tube=======
10 cz 0.57
11 cz 0.61
C ===========Lattice===================
12 px 0.627
13 px -0.627
14 py 0.627
15 py -0.627
C ====Assembly=====
16 px 10.659
17 px -10.659
18 py 10.659
19 py -10.659
c =====Surround of assembly===========
*20 px 10.75
*21 px -10.75
*22 py 10.75
*23 py -10.75
c ======SLOBA geometry================
50 cz 0.2000
51 cz 0.3700
52 cz 0.3800
53 cz 0.4100
54 cz 0.4316
55 cz 0.4760
C ======== Data Card ==========
kcode 1000 1.0000 50 200
ksrc 10.032 0 0 -10.032 0 0
0 10.032 0 0 -10.032 0
10.032 10.032 0 -10.032 -10.032 0
BURN TIME 0.1 0.2 0.3 0.4 1 2 10 15 25
POWER 1.0
MAT 1
MATVOL 86552.05632
BOPT 1 14 1
OMIT=1 8 90233 90234 91232 93235 93236 93239 94236 94237
C ======== Material Card ======
c UO2 d=10.17g/cc
m1 92235 -0.0436342
92238 -0.837866
8016 -0.1185
c --- cladding Zircaloy-4 d=6.560 g/cc ----------
m2 8016 -0.001196
24000 -0.000997
26000 -0.001994
40000 -0.981858
50000 -0.013955
c -------water d=1g/cc
m3 1001 -0.111894 8016 -0.888106
c -------He gas d=0.000166
c m4 2004 -1.0
c -------SLOBA 15% B4C-Al2O3 d=3.520 g/cc
m5 5010 -0.023470
5011 -0.093910
8016 -0.400130
24000 -0.449860
6000 -0.032600
c -------Air d=0.001205g/cc
m6 6000 -0.000124
7014 -0.755268
8016 -0.231781
18000 -0.012827
please kindly help, and i couldn't find the problem at all.
I also ran into this problem. My source file is a bit more complex, but it boiled down to the following problem:
1. Physics models were disabled. Why? Dunno. It seems like literally every source file I write I get this message.
2. An isotope without tables was encountered.
3. In order to estimate the behavior of this isotope under radiation it needs to have physics models enabled or a lookup table in the burn up.
In your out file there should be a line telling you what zaid of the isotope(s) it's choking on, for me this happened to be 64151 (which is a stable isotope of Gadolinium apparently, I never specified it in my input file, but I guess as part of the burnup calculation it was generated.)
Here's my omit block:
OMIT=-1 114,6014,7016,8018,9018,10021,10022,12023,
12027,13026,13028,14027,14031,16031,16037,
17034,17036,17038,18037,18039,18041,18042,
19042,19038,19043,20039,20041,20045,20047,
21044,21046,21047,21048,2045,22051,223047,
23048,23049,23050,23052,23053,23054,24049,
24051,24052,24055,24056,25051,25052,25053,
25054,25056,25057,25058,26053,26055,26059,
26060,27057,27060,27061,27062,27063,28057,
28063,28065,29062,29064,29066,30064,30065,
30066,30067,30068,39087,39092,39093,40088,
40089,40097,41091,41092,41093,41096,41097,
41098,41099,41100,42093,42091,42101,43097,
43098,44097,54127,56131,58137,64151,90231,
90234,90233,91230,91232,93235,93236,94243,
94244,94236,94237,95240,95244,97245,97246,
97247,97248
I haven't tried to run your code, but one thing that may be helpful is to specify which cross section libraries you want to use. You'll need to consult the manual to see which ones match your problem best, but you'll probably be fine in using .80c. So for each ZAID, try this: for Hydrogen, instead of using 1001, use 1001.80c. For O-16, use 8016.80c. Etc etc.
OK, this is a very old thread. But I just learned the answer. You need to use the MPHYS card to turn on model physics.
MPHYS ON
By default it's off. The error message is pretty weird.
Likes gsyuan
What is a fatal error in MCNP6?
A fatal error in MCNP6 is an error that causes the program to terminate and stop running. It is typically caused by a critical mistake in the input file or an issue with the computer's memory or hardware.
Why am I getting a fatal error in MCNP6?
There could be several reasons for a fatal error in MCNP6, such as an incorrect input file, incompatible hardware, or insufficient memory. It is important to carefully review the input file and ensure that all parameters are entered correctly.
How can I fix a fatal error in MCNP6?
The first step in fixing a fatal error in MCNP6 is to carefully review the input file and make any necessary corrections. If the error persists, it may be necessary to check for compatibility issues with the computer's hardware or allocate more memory to the program.
Can I prevent fatal errors in MCNP6?
While it is not always possible to prevent fatal errors in MCNP6, there are some steps you can take to minimize the likelihood of encountering them. These include ensuring that the input file is entered correctly, using compatible hardware, and allocating sufficient memory to the program.
Is there a way to recover data after a fatal error in MCNP6?
In most cases, data cannot be recovered after a fatal error in MCNP6 since the program terminates and stops running. It is important to save your work frequently to minimize any potential loss of data in the event of a fatal error.
  • Nuclear Engineering
