B Why does Fdt go away during collisions while Fdx does not?
During collisions between particles, Fdt goes to zero due to the equal and opposite forces acting on the two colliding objects, which allows for the conservation of linear momentum. In contrast, Fdx does not vanish, as it represents the work done during the collision, which can be converted into other forms of energy. The discussion highlights that while momentum is conserved in both elastic and plastic collisions, kinetic energy is only conserved in elastic collisions. The confusion arises from the treatment of forces acting on different systems, where internal forces cancel out, but the work done (Fdx) remains significant. Overall, the key distinction is that Fdt reflects instantaneous forces that balance out, while Fdx accounts for the energy changes during the collision.
JLT
For collisions between particles, Fdt goes to zero while Fdx does not
F = mdv/dt
mv + Fdt = mv
if you have two particles colliding
mva + mvb +Fdt = mva'+mvb'
in the above case, Fdt goes away as there are equal and opposite forces between the two particles during the collision, linear momentum is conserved
but
F = m(dv/dt)(dx/dx)=m(dx/dt)(dv/dx)=mv(dv/dx)
Fdx = mvdv
KE1 + Fdx = KE2
Fdx does not go away during a collision.
JLT said:
mv + Fdt = mv
Where did this come from?
I don't understand. Why are you adding forces on two different objects?
forces between two colliding objects. you can set it up so that momentum is conserved, while energy is not conserved.
Both momentum and energy are conserved, but energy can be converted from KE to other forms.
But I still don't get why you are adding the forces on two objects. If I have two forces acting on one system then I can add them and get the net force. But if you have two forces acting on two different systems then you don't add them in any meaningful way.
Sorry, I should have put a summation sign on the forces:
mVa + mVb + Fab dt + Fba dt = mVa' + mVb' → forces are equal and opposite, cancel out, and you get conservation of linear momentum
0.5 mVa^2 + 0.5mVb^2 + Fab dx + Fba dx = 0.5 m Va'^2 + 0.5 m Vb'^2
I think it is because part of dx does not restore itself after the collision, even though Fab=-Fba Fdx is a scalar quantity not a vector and the magnitudes do not cancel out.
JLT said:
Fab dt + Fba dt
Why are you adding Fab and Fba, they are acting on two different systems.
This: https://en.wikipedia.org/wiki/Elastic_collision
vs. this: https://en.wikipedia.org/wiki/Inelastic_collision#Perfectly_inelastic_collision
Elastic has conserved energy, while plastic does not. Fdt vs. Fdx. Fdt goes to zero (equal and opposite pairs), Fdx does not go to zero even though it is still equal and opposite pairs??
mava + mbvb + 0 = mava' + mbvb' → this works for both elastic and plastic collisions, Fdt does not care if it is elastic or plastic
0.5mava^2 + 0.5mavb^2 + Fdx = 0.5mava'^2 + 0.5mavb'^2 → Fdx only goes to zero for elastic collisions??
F = mdv/dt
mv + Fdt = mv
The formulas in blue are not meaningful. You are adding finite terms (like mv) with terms containing infinitesimals (Fdt).
If you look at the momenta before and after collision, the difference is not Fdt but the integral of Fdt over the duration of collision.
Fdt does not "go to zero" during the collision but the integral (over the duration of interaction) may if there are no forces external to the system under consideration.
Same observation applies to the equations where you add Fdx to finite terms.
mva + mvb +Fabdt+Fbadt = mva'+mvb'
Fab = Fba → internal equal and opposite forces, so in the absence of external forces momentum is conserved.
0.5mava^2 + 0.5mavb^2 + Fabdx+Fbadx = 0.5mava'^2 + 0.5mavb'^2
Same scenario, Fab = Fba, only energy is not conserved if the collision is plastic (e < 1)
mv does not care if the collision is an elastic collision (e = 1) or a plastic collision
