[FDTD/Fotran] detected reflection near boundary but don't know why
The discussion centers on a 2D finite-difference time-domain (FDTD) simulation where reflections occur at the boundary of different permittivities (epsilon) in the model. The user reports that reflections become noticeable after 50 timesteps as the wave approaches the boundary defined by coordinates (i1, i2) = (25, 75) and (j1, j2) = (25, 75). The issue is identified as impedance mismatch, which arises because wave impedance is inversely proportional to the square root of permittivity. Specifically, the impedance for epsilon = 1 is 1.414 times greater than for epsilon = 2, leading to reflections at the interface. The user seeks solutions to correct this impedance mismatch in the simulation, but has not received specific advice on how to address the issue.
s_hy
hi all,
i have wrote codes for 2d fdtd in different permittivity (epsilon). in this code, cell size is 200 x 200, start with eps=1 from center, and different permittivity started at boundary (i1,i2) = (25,75) = (j1,j2), epsilon = 2. the problem is, when the wave propagates and approach (i1,i2) = (25,75) = (j1,j2), i have detected some reflections happened to the wave at timesteps, n after 50, the reflections become obvious...i just wondering, why is that happened. i attached here the animation of the wave and my codes. i really have no idea how to solve this problem.
Code:
subroutine test7
implicit none
double precision                                     :: f0,A0
double precision                                     :: delta, deltat
double precision                                     :: eps0,epsr,miu0,miur
double precision                                     :: lamda
double precision                                     :: omega
double precision                                     :: S,k,c
integer                                                     :: i,j
integer                                                     :: ie,je,ic,jc,i1,i2,j1,j2
integer                                                     :: n
double precision,dimension(202,202)   :: Ez,Hy,Hx
double precision,dimension(202,202)   :: Ca,Cb,Da,Db,Dax,Dbx,Day,Dby
!double precision                                     :: Ca,Cb,Da,Db
double precision,dimension(202,202)   :: miu,eps,sigma, sigmat
double precision, parameter                 :: pi = 3.14159265
character(len=20)                                   :: filename
! parameters
 f0 = 3.0e7
 eps0 = 8.8e-12
 miu0 =  4*pi*1e-7
 c = 3.e8
 lamda = c/f0
 omega = 2*pi*f0
 print *, 'lamda=',lamda
 A0 = 5.0
 k = 2*pi / lamda
 omega = c*k
!courant stability factor
 !S = 1/sqrt(2.0)
! spatial and time grid steps
 delta = lamda/10
 deltat = delta/(2*c)
 print *, 'deltat=',deltat
!model size
 ie = 100
 je = 100
 !source location
 ic = ie/2
 jc = je/2
 !boundary for different permittivity
 i1 = ie/4
 i2 = ie*3/4
 j1 = je/4
 j2 = je*3/4
print*, 'see me?'
!initialize Ez, Hx,Hy to zero at t=0
do i = 1,ie
 do j = 1,je
   Hx(i,j) = 0.0
   Hy(i,j) = 0.0
   Ez(i,j) = 0.0
 end do
end do
!medium's properties
 miur = 1.0
 epsr = 1.0
  do i = 1,ie
   do j = 1,je
     !initialize permittivity and permeability
     eps(i,j) = epsr*eps0
     miu(i,j) = miur*miu0
   end do
  end do
  do i = i1,i2
    do j = j1,j2
     eps(i,j) = 2*eps0
     miu(i,j) = 1*miu0
    end do
 end do
! initialize electric conductivity & magnetic conductivity
  do i = 1,ie
   do j = 1,je
     sigma(i,j) = 0.0
     sigmat(i,j) = 0.0
     Ca(i,j) = (2*eps(i,j)-deltat*sigma(i,j))/(2*eps(i,j)+deltat*sigma(i,j))
     Cb(i,j) = (2*deltat)/(2*eps(i,j)+deltat*sigma(i,j))
     Da(i,j) = (2*miu(i,j)-deltat*sigmat(i,j))/(2*miu(i,j)+deltat*sigmat(i,j))
     Db(i,j) = (2*deltat)/(2*miu(i,j)+deltat*sigmat(i,j))
   end do
  end do
! beginning of timesteps
 do n = 1,300
  write (filename, "('data',I3.3,'.dat')") n
  open (unit=130,file=filename)
!initiate sinusoidal wavepulse at center
  Ez(ic,jc) = A0*sin(2*pi*f0*n*deltat)
! calculate ez-field
  do i = 2,ie-1
    do j = 2,je-1
          Ez(i,j) = Ca(i,j)*Ez(i,j) + Cb(i,j)*(Hy(i,j) - Hy(i-1,j) - Hx(i,j) + Hx(i,j-1))
          write (130,*) i,j,Ez(i,j)
          if (j == 99) write (130,*) ' '
!          !print *,'i=',i,'j=',j,'Ez(i,j)=',Ez(i,j)
    end do
  end do
  do i = 1,ie-1
    do j = 1,je-1
	  Hx(i,j) = Da(i,j)*Hx(i,j) + Db(i,j)*(Ez(i,j) - Ez(i,j+1))
          !print *,'i=',i,'j=',j,'Hx(i,j)=',Hx(i,j)
     end do
  end do
    do i = 1,ie-1
     do j = 1,je-1
          Hy(i,j) = Da(i,j)*Hy(i,j) + Db(i,j)*(Ez(i+1,j) - Ez(i,j))
          !print *,'i=',i,'j=',j,'Hy(i,j)=',Hy(i,j)
     end do
  end do
close (unit=130)
end do !n
end SUBROUTINE test7
Technology news on Phys.org
thank you for the reply. i just found out the problem caused by impedance mismatch. it is happened when i use different epsilon. wave impedance inversely proportional to the square of epsilon. So epsilon =1 wave impedance value is 1.414 times greater than epsilon= 2. If there is any impedance mismatch between the two layers it will create reflection. then, another problem, i found the cause of problem, but have no idea how to correct impedance mismatch in my simulation. do you have any idea?
I'm sorry, but as I have never used FDTD or worked with that kind of problem, I have no advice to give you.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
