What is the effective mass of electrons and holes in germanium?
The discussion focuses on calculating the densities of states for germanium, specifically at energy levels 0.08 eV above the conduction band edge and 0.08 eV below the valence band edge. Participants express confusion regarding the application of constants and the calculation of volume density of states, particularly the use of a factor of 10^-22 related to the sample volume. There is also a debate about the accuracy of intermediate results, with one participant questioning the order of magnitude in a provided example. The effective mass of electrons and holes in germanium is highlighted as crucial for these calculations, noting that it differs significantly from silicon. Understanding these concepts is essential for accurate computations in semiconductor physics.
orangeincup
Find the densities of states 0.08 eV above the conduction band edge and 0.08 eV below the valence band edge for germanium.
Find the volume density of states (i.e. number of states per unit volume) with energies between the conduction band edge and 0.4 eV above the conduction band edge for germanium.
8pisqrt2/h^3*m^(3/2)sqrt(E-Ec)
Using this example as a reference http://ecee.colorado.edu/~bart/book/book/chapter2/pdf/ex2_3.pdf
m=6*10^18, in the example they ignored the *10^-18 on their 1.08 value
(((8pisqrt2*(9.10*10^-31*6)^(3/2))/(6.626*10^-34)^3))sqrt(.08*1.6*10^-19)
=1.76*10^47 m^-3J^-1
Why should I times it by *10^-22, like in the example above? What is the purpose of that or is it an error?
In the example above I don't understand how they calculated that or reduced their value so low. I tried it with the same numbers they gave and it didn't work at all.
This value seems way too high. I need to convert it to eV.
Part 2)
Should I use .02 for this example, for my E-Ec value?
This should be posted in the advanced physics forum.
I'm no expert on this topic, but I note that 10^-22 is the volume of the sample they are using (100 x 100 x 10 nm3) in cubic meters. I note also that the units of their formula work out to J-1 m-3, so to yield a result in J-1 multiplying by a volume is called for.
I further note that their intermediate result: 1.51 x 1056 m-3 J-1 is suspect. Plugging in their values I get an order of magnitude of 1046 rather than 1056, however their final result looks fine.
Are you sure you posted all of the information given in the question? You need the effective mass of electrons and holes in germanium to work that out. (The values are very different to the values for silicon.)
