Undergrad Position of Fermi Energy for Semi-Conductors
The position of Fermi energy in semiconductors is typically found between the upper end of the valence band and the lower end of the conduction band, rather than at the center of the energy gap. At absolute zero (0 K), the Fermi level for intrinsic semiconductors is located in the middle of the energy gap, while for other semiconductors or insulators, it exists somewhere within the gap. The distinction between Fermi energy and Fermi level is clarified, with Fermi energy representing the highest occupied energy level at 0 K. The work function is also significant for semiconductors, particularly in applications like photocathodes, where it defines the photoemission threshold. Understanding these concepts is crucial for applications in semiconductor technology and materials science.
M.A.M.Abed
what i mean exactly what is the position of Fermi energy for semi conductor materials
1- at the highest of valance band
2- at the mid-way in energy gap like Fermi level at 0 K
it would be helpful if you could rephrase your question in complete sentences.
M.A.M.Abed said:
I ll do
You didn't..
Zz..
ZapperZ said:
You didn't..
Zz..
I did
The precise definition of the Fermi energy is the value of the chemical potential of the electrons in the limit ##T \to 0 ##K. This value may or may not coincide with an energy level of the system. In semiconductors it is somewhere between the upper end of the valence band and the lower end of the conduction band, not necessarily in the center.
Likes berkeman
I know that it doesn't necessarily in the center.
also i know the difference between Fermi energy and Fermi level
also i know that Fermi level tends to be the same of Fermi energy at limit T=0 K
Fermi level is the level with probability 50% to occupies also represent the same electron chemical potential
Fermi energy is the difference between the max energy and the ground state energy (highest occupied level at T=0 K )
i am confused if Fermi energy highest occupied level at T=0 K which separate full levels under it and empty above it
if it in the energy gap it will be empty which contradict with definition (highest occupied level at T=0 K)
In the energy gap there is no level, so it makes no sense to say it is empty or not. In a semiconductor you have a well defined Fermi energy, but no Fermi level.
yea the density of at it equal to zero
thank you
put what you mean by In a semiconductor you have a well defined Fermi energy
also is there any importance to define a work function for semi conductor or insulators since Fermi level in the energy gap ??
Yes, there is an "importance" to defining a work function for a semiconductor. In some cases, it is defined as the sum of the energy gap and the electron affinity. It is important because many semiconductors are being used a photocathode in an electron source, and the work function here defines the photoemission threshold.
Zz.
Likes M.A.M.Abed
Zz.
Thnx in advance
last question sorry the Fermi energy at insulators is the top level of valance band and Fermi level for ideal case in the middle of energy gap am i right ?
M.A.M.Abed said:
Thnx in advance
No, this is not correct. The Fermi level for insulators is somewhere in the gap.
Ideal case of what?
Zz.
Ideal case of what?
Zz.
for pure semiconductor at T=0 K
there is a misunderstanding between fermi level and fermi energy
just tell me where fermi level and fermi energy exist at zero absolute temperature for semiconductors
For an intrinsic semiconductor, it is located in the middle of the gap. For any other semiconductor or insulator, it is SOMEWHERE in the gap.
Zz.
It's called valence not valance.
Zz.
yea this is the Fermi level
what about Fermi energy (highest occupied energy at T=0 K)
No, because the density of states is usually different in the valence and conduction band. At finite temperatures, this would lead to an excess of electrons in the band with the higher DOS. Hence the chemical potential has to be further away from the band with the higher DOS. This also holds in the limit of zero temperature.
Not according to the simplified version that is used in many textbooks at this level. And I highly doubt that the OP is dealing with the knowledge of band structure of materials to understand this issue.
Zz.
The "Fermi level" IS the "Fermi energy", unless you are dealing with momentum space, which you're not. You are only tackling the cartoon energy band diagram, which is in "energy space", and they are the same thing, i.e. this is often mixed with the chemical potential.
Zz.
Thnx
