Calculating Average Acceleration on a Ferris Wheel
To calculate the average acceleration of a passenger on a Ferris wheel with a radius of 14.2m completing one revolution in 10.1 seconds, the relevant formula is a = (vf - vi)/t, where vf and vi are the final and initial velocities, respectively. Since the passenger starts and ends at the lowest point, both velocities are zero, resulting in an average acceleration of 0 m/s² over the 5.05-second interval. The formula a = (-rwcoswt)i + (-rwsinwt)j is for instantaneous acceleration, not average acceleration. Understanding the distinction between average and instantaneous acceleration is crucial for solving this type of problem. The average acceleration indicates that the passenger's speed and direction remain unchanged during the specified time.
ffrpg
The problems reads, A carnival Ferris wheel has a 14.2m radius and completes one revolution about its horizontal axis in 10.1s. Consider the time interval from the instant when a passenger is at the lowest point of the uniform circular motion to a clock reading 5.05 seconds later. What was the magnitude of the passenger's average acceleration during this time interval?
Do I use the formula (they're suppose to be vectors) a=(-rwcoswt)i+(-rwsinwt)j? I really don't have any direction towards solving this problem. Any hints would be wonderful.
That should be:
a=-rω2cos(ωt)i-rω2sin(ωt)j
You forgot to square the angular velocity, but other than that it's OK.
To calculate the average acceleration of the passenger on the Ferris wheel, we can use the formula a = (vf - vi)/t, where vf is the final velocity, vi is the initial velocity, and t is the time interval. In this case, the passenger's initial velocity is zero, since they start at the lowest point of the Ferris wheel, and their final velocity is also zero, since they return to the same point after one revolution.
So, we can rewrite the formula as a = (0 - 0)/5.05 = 0 m/s^2. This means that the passenger's average acceleration during this time interval is zero, indicating that their speed and direction did not change.
To answer your question about using the formula a = (-rwcoswt)i + (-rwsinwt)j, this formula is used to calculate the instantaneous acceleration at a specific point on the Ferris wheel, taking into account the position, velocity, and angular velocity of the wheel. In this problem, we are looking for the average acceleration over a time interval, so we do not need to use this formula.
I hope this helps! Let me know if you have any further questions.
If have close pipe system with water inside pressurized at P1= 200 000Pa absolute, density 1000kg/m3, wider pipe diameter=2cm, contraction pipe diameter=1.49cm, that is contraction area ratio A1/A2=1.8 a) If water is stationary(pump OFF) and if I drill a hole anywhere at pipe, water will leak out, because pressure(200kPa) inside is higher than atmospheric pressure (101 325Pa). b)If I turn on pump and water start flowing with with v1=10m/s in A1 wider section, from Bernoulli equation I...
16K
  • · Replies 16 ·
11K
