Ferrite Cores on the output cable of a VFD
This discussion centers on the use of ferrite cores with Variable Frequency Drives (VFDs) to mitigate electromagnetic interference (EMI). It highlights that manufacturers like Allen Bradley often provide ferrite cores to comply with FCC regulations, but external cores are typically unnecessary unless EMI issues are present. The conversation also explains that the switching frequency of the VFD, such as 8 kHz, generates harmonics that extend into the MHz range, necessitating the use of high-frequency ferrites for effective noise reduction. Users are encouraged to consult manufacturer guidelines and consider standard EMI ferrite cores if issues arise.
  • Understanding of Variable Frequency Drives (VFDs) and their operation
  • Knowledge of electromagnetic interference (EMI) principles
  • Familiarity with ferrite core materials and their applications
  • Basic grasp of harmonic frequencies and their calculations
  • Research the specifications and applications of Material 43 ferrite cores
  • Learn about EMI test certifications for industrial equipment
  • Explore the design kits available from ferrite core manufacturers like Heilind and Fair-Rite
  • Investigate methods for measuring and diagnosing EMI issues in electrical systems
Electrical engineers, technicians working with VFDs, and professionals involved in EMI mitigation strategies will benefit from this discussion.
Dinoduck94
TL;DR
How to size a Ferrite core on the outgoing cable of a Variable Frequency Drive
Some Variable Frequency Drive manufacturers (such as Allen Bradley) supply a toroidal Ferrite core to wrap the outgoing cables around to reduce EMF.
My question is, if a company doesn't supply a ferrite core, how do I work out if one is needed, and how do I correctly size it?
I understand that the switching frequency can be set to either 2, 4, 8 or 16kHz - so would this be the frequency that I'd use? If so, how come a lot of ferrites seem to operate in the MHz range?
Thanks
Dinoduck94 said:
... to reduce EMF. ...
I think you mean EMI.
Dinoduck94 said:
... how do I work out if one is needed, and how do I correctly size it?
There may be one inside the VFD. You do not need one if there is not an EMI problem, are you looking for more problems?
The manufacturer may be required by the FCC in USA, to take some action to reduce EMI. Providing a core with the device satisfies that legal requirement. An external core is usually not needed.
An 8 kHz square wave has harmonics that go all the way up to MHz.
Since all wires pass through the ferrite toroid in the same direction, it is being used to remove common mode noise, the power currents are cancelled. The RF EMI is at MHz frequencies so it requires a high frequency ferrite rather than an iron powder core.
I agree with @Baluncore -- as long as the VFD has a CE Mark on it and an EMI test certification (most likely to "Level A" for industrial equipment), and as long as you currently do not have radiated EMI issues with the other equipment in your installation, I wouldn't worry about it.
If you *are* having EMI issues that are related to the VFD (they stop when you turn off that drive), then check with the manufacturer to see what they recommend. If this is an off-brand VFD with no obvious customer support available, then start with standard EMI ferrite cores (maybe Material 43 or lower frequency). You can order design kits from the ferrite core manufacturers for doing such investigative work. Take a look at the ferrite kits from these manufacturers, for example:
https://www.heilind.com/products/steward/brochure_ferrite_emi_cores.pdf
https://www.fair-rite.com/
Thanks all for your responses.
Agreed that it generally isn't something to worry about, but I don't want to be an engineer that doesn't understand EMI and only looks to solve an issue once it has been experienced. I want to be proactive and to know when I am likely to have an EMI issue, and know how best to resolve it - hence me looking into Ferrite cores.
When you say that the harmonics go all the way up to MHz, how do I find out what the harmonic frequency of an VFD is? Is the a general rule of thumb?
If I'm to size a ferrite core then I assume it's this harmonic frequency that I would need to use in any calculation?
I will have a look at these ferrite design kits - thank you.
A square wave has odd harmonics. An 8 kHz fundamental sinewave has harmonics of
H3 = 3*8 kHz = 24 kHz;
H5 = 5*8 kHz = 40 kHz;
H7 = 7*8 kHz = 56 kHz; … all the way to;
H125 = 125*8 kHz = 1 MHz; … and above that.
https://en.wikipedia.org/wiki/Square_wave#Fourier_analysis
The relative amplitude of the n'th harmonic will be 1/n; so the 3'rd harmonic will have an amplitude of 1/3; and the 125'th harmonic will have a relative amplitude of 1/125 = 0.008 = 0.8% = 42 dB down.
The high frequency edges of the internal switching may escape along the output cable. Most will be significantly attenuated by filters in the VFD. You will need to identify if and where in the spectrum EMI is actually a problem.
For a VFD switching at 8 kHz, and using an AM radio, you should be able to hear the odd harmonics every 16 kHz across the band. There will also be other harmonic noise from other nearby switching supplies. Turn the VFD off and on again to confirm the VFD is the source of the EMI.
  • · Replies 58 ·
9K
