Few Questions Needed Help With
  • Thread starter Thread starter bgallz
bgallz
Hi there, I have a few problems that I am struggling with. The answers in the back of the textbook don't give explanations and my answer comes out different.
a. (From 0 to 1) \intln(x) dx
I took this as [1/x]. So I did 1/1 - 1/0 = 1. Is that correct?
b. (From 0 to 3) \int1 / (x-1)2 dx
I used u substitution.
u = x-1
du = dx
New integral: (From 0 to 3)\int1 / u2 du.
Taking the integral: u-2 = - 1 / u => -1 / x-1. Then I took it from 0 to 3.
(- 1 / 3 - 1) - (-1 / 0 - 1) = (-1/2) - (1/1) = -3/2. I got a 7/10 on this one. :\
c. (From 1 to e)\intx2*ln(x) dx
I turned this into integration by parts like this:
u = ln(x)
du = 1/x dx
dv = x2
v = (x3)/3
So uv - \intv du = ln(x)*(x3/3) - \int(x3/3)*1/x dx. I eventually got down to:
1/3[x3ln(x)] - 1/9[e3 - 1] + C
Is that correct? This problem isn't given an answer but my original try was definitely wrong. lol
Thank you so much for any help!
welcome to pf!
hi bgallz! welcome to pf! :smile:
1. erm :redface: … the derivative of lnx is 1/x, isn't it?
2. would be ok, except that everything is infinite at x = 1 :frown:
that isn't finished :confused:
(and how can a definite integral have a C ?)
Hey thanks for the reply.
1. I thought that taking the integral of ln(x) is also 1/x. But it looks like this right here proves that wrong:
http://math2.org/math/integrals/more/ln.htm
2. Ah yes I totally overlooked that. So I would have to break it up into 2 integrals right? One from 0 to 1 and one from 1 to 3? I forget how that works.
3. Do you mean that I have to calculate e^3 - 1? And yea I don't know why I put the C there.
Thanks!
hi bgallz! :smile:
yes (though if they're ±∞, the sum would be indeterminate)
no, i mean you still have x in the first part
Can you explain that first part about breaking it up?
And for the 3rd one, I have to run that uv part from 1 to e as well?
if you draw the graph, you can see that it obviously has a discontinuity, where it goes off to ±∞
yes, everything in integration by parts goes between the same limits :smile:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
