PeterDonis
Mentor
- 49,667
- 25,778
It depends on what you mean by "possible". If you're willing to basically give up any connection to how the diagrams are actually used, you can of course imagine that each line represents an infinity of lines between two vertices, since "the photon could take any path". Nobody can stop you. But I don't see the point, since as soon as you try to actually use the diagrams for anything, which means actually writing down and evaluating the corresponding integrals, what you see in the math will not match what you have been imagining.Husserliana97 said:I just wanted to know if this "description" in space-time was still possible
Yes, but only at a very simple level. For example, note what I said explicitly about the "infinite number of lines" thing:Husserliana97 said:in your previous answers (still in this same thread), you seemed to build the diagram in this space-time image.
In other words, I was using that description as a (simplistic spacetime) description of one particular diagram. I was not using it as a way of describing what lines mean in any diagram whatsoever.PeterDonis said:When we talk about light "taking different routes", we are basically talking about one Feynman diagram: the one that has just one photon line coming in and one photon line going out, with nothing happening in between.
It's also worth looking at why that simplistic spacetime description of that one particular diagram is used. It's used because, experimentally, for that one simple process, we can actually investigate its implications. Feynman describes this in some detail in the QED book I mentioned: basically, we can test, experimentally, whether light that starts at one fixed point in spacetime and ends up at another fixed point in spacetime takes multiple paths through spacetime in between, by obstructing some of the paths and seeing if it changes the behavior (for example, Feynman describes diffraction this way--by cutting off some of the possible multiple paths, you can change the observed behavior of the light).
But for a line in an arbitrary Feynman diagram, where at most one end (if it's an external leg), or more likely neither end (if it's a purely internal line), are even accessible to experiment at all, we have no way of testing whether such a line actually, physically corresponds to "multiple paths". So if we still use the "multiple paths" description at all, it can only be as a story to tell that sounds good, without actually conveying any useful information. That's why, as more details got asked for in this thread, I backed away from the simplistic spacetime viewpoint and started talking about how diagrams actually get evaluated in the momentum space representation.
