Fictitious Forces: Science Fiction & Fantasy
The discussion revolves around the concept of fictitious forces, particularly in the context of rotating frames of reference. Participants explore the nature of these forces, their classifications, and the implications of motion within rotating systems.
  • Some participants discuss the mathematical formulation of motion in a rotating frame, noting the relationship between frequency, angular frequency, and period of oscillation.
  • There is a confusion expressed regarding the distinction between inertial and non-inertial frames, particularly in the context of a mass inside a rotating sphere.
  • Participants clarify that in a non-inertial frame, fictitious forces such as centripetal and centrifugal forces arise, affecting the motion of the mass.
  • One participant questions the categorization of fictitious forces and whether they must fit into established categories like centrifugal, linear, Coriolis, and azimuthal forces.
  • Another participant suggests that the fictitious force in the rotating sphere scenario can be considered centrifugal but with a negative value, indicating a directionality in the force's effect.
  • There is mention of the need for understanding coordinate transformations to clarify the behavior of forces in different frames of reference.
  • Some participants propose that the fictitious force can be a combination of centrifugal and Coriolis forces, with their interplay determining the net effect on the mass's motion.
Participants express varying levels of understanding regarding fictitious forces and their classifications. There is no consensus on the categorization of these forces or the implications of their interactions in rotating frames, indicating ongoing debate and exploration of the topic.
Some participants note potential confusion arising from the definitions of inertial versus non-inertial frames and the mathematical treatment of forces in these contexts. The discussion reflects a range of assumptions and interpretations that are not fully resolved.
This discussion may be of interest to those studying physics, particularly in areas related to mechanics, rotating systems, and the concept of fictitious forces in non-inertial frames.
greendog77
[N/A]
Yes, in the rotating frame the "centrifugal force" has magnitude ##m\omega^{2} x##, and the equation of motion of the ball is
##\frac{d^{2}x}{dt^{2}}=-(2k-m\omega^{2})x##
Therefore, the frequency of oscillation in radians/second is ##\sqrt{\frac{2k-m\omega^{2}}{m}}## and in periods/second it is ##\frac{1}{2\pi}\sqrt{\frac{2k-m\omega^{2}}{m}}##. The period of oscillation is the reciprocal of the latter expression: ##T=2\pi\sqrt{\frac{m}{2k-m\omega^{2}}}##. You only made a small error in how frequency, angular frequency and period are related to each other. You can avoid this kind of mistakes by checking that your answer has correct dimensions.
I was going more for the concept of fictitious forces. What I'm confused about is that if you leave a small mass in a larger sphere, and rotate the sphere with angular velocity w, the small mass would travel in a straight line to the edge of the sphere in the inertial frame of the sphere. However, this isn't really true, as the mass simply travels in a circle in the inertial frame of the sphere. What's wrong here?
It seems you're confusing the terms "inertial" and "non-inertial" here. The rotating frame, where centrifugal effects arise, is non-inertial, not inertial.
If you have a mass at rest inside a rotating sphere, the sphere exerts no force on the mass. When you transform to the rotating rest frame of the sphere, there is an apparent inward centripetal force on the mass and it travels on a circular trajectory. In the "ball-inside-tube" problem, the ball was constrained to have same angular velocity as the tube (the walls of the tube exert a force on the ball) and the situation was opposite, leading to a centrifugal force.
Hmm so what is the fictitious force for the rotating sphere scenario?
If you take the equation of motion of the mass in rotating sphere, and transform to a rotating coordinate system, a term appears that describes an inward centripetal force. That is the fictitious force in this situation.
I thought the four base fictitious forces were centrifugal, linear, coriolis, and azimuthal. So does that mean fictitious forces don't necessarily have to fall within those categories? Under what circumstances do they fall under those categories? You mentioned the ball is constrained to have the same angular velocity as the tube. Why does that cause it to have a centrifugal force instead of a centripetal fictitious force?
In the rotating sphere scenario, the fictitious force falls in the centrifugal category, it just has a negative value in that case.
You probably haven't studied coordinate transformations yet. The confusion disappears when you learn how to actually transform the eqs of motion and see how they look like in different non-inertial frames.
The inertially moving mass moves straight in the non-rotating frame. In the roating frame is moves on a cruved path. This is attributed to fictitious forces (centrifugal & coriolis).
https://www.youtube.com/watch?v=49JwbrXcPjc
In this example the fictitious force is a combination of centrifuge (away from the center) and Coriolis (towards the center. The Coriolis is larger than the centrifuge giving a net fictitious force towards the center which turns out to exactly what is needed to provide the centripetal force (towards the center) required to keep the object in circular motion.
Thank you all! This makes complete sense to me now.
  • · Replies 114 ·
  • · Replies 153 ·
12K
  • · Replies 21 ·
  • · Replies 50 ·
  • · Replies 29 ·
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 16 ·
