Field Emission from Metals: What is the Truth?
  • Context: Graduate
  • Thread starter Thread starter grandmessage
    Emission Field Metals
The discussion revolves around the field emission of electrons from metals, specifically addressing the minimum electric field required for this process and the implications of the Fowler-Nordheim formula. Participants explore the differences between field emission and tunneling, as well as the conditions under which significant current densities can be achieved.
  • Some participants note that literature suggests a minimum field of approximately 10^7 V/cm for electron field emission from metals, while the Fowler-Nordheim formula indicates considerable current density at lower fields around 10^4 V/cm.
  • One participant distinguishes between field emission, which involves ejecting electrons to the vacuum level, and Fowler-Nordheim tunneling, which occurs between materials and may require lower energy barriers.
  • Another participant references a simplified form of the Fowler-Nordheim equation, suggesting that for a metal with a work function of 5 eV and a local electric field of 10^4 V/cm, a field emission current density of 0.1 mA/cm² can be achieved.
  • A later reply challenges the notion of a "required field," stating that tunneling can theoretically occur at zero field, though it may be unlikely, and emphasizes that field emission can happen over a range of fields.
  • There is a contention regarding the applicability of the Fowler-Nordheim model to metal-vacuum interfaces, with one participant asserting that it does apply, contrary to an earlier claim.
Participants express differing views on the minimum field required for field emission and the applicability of the Fowler-Nordheim formula. There is no consensus on these points, and the discussion remains unresolved.
Participants highlight the complexity of the topic, including the dependence on definitions of tunneling and field emission, as well as the influence of experimental conditions on observed current densities.
grandmessage
Hello everyone,
a number of books and web articles says that the minimum field required is ≈[itex]10^7V/cm[/itex] for electrons field emission/tunneling from the surface of metals.
But fowler-nordheim formula shows that there is still considerable amount of field emission
current density (mA/cm2) even at lower fields of order [itex]10^4V/cm[/itex], for the same
tunneling barrier.
What is the truth..??
Any answers would be greatly appreciated!
Two very different things. Field emission from the surface of a metal involves ejecting the electron to the vacuum level, i.e. it becomes entirely free from the metal and goes off into the environment. This a large energy compared to the thermal energy so a electric strong field is needed.
Fowler-Nordheim tunneling refers to tunneling from the metal to either a semiconductor or another metal, i.e. this is material to material NOT material to vacuum. This is usually a much lower energy. You just have to overcome some tunnel barrier like an insulator or the semiconductor's Schottky barrier. If the barrier is thin and/or low, then a strong field is not needed.
Hello sir,
Please check the Link here,
Where we can find simplified form of Fowler-Nordheim equation here also they says the minimum field required is [itex]3×10^7 V/cm[/itex].
But for a metal of work function ∅=5eV and local electric field(E-local) [itex]10^4V/cm[/itex]
it gives a minimum filed emission current density [itex]0.1mA/cm^2[/itex]..
Is this true..??
Back up a bit, because there's a bunch of things I don't quite understand here.
First of all, there is no "required field". By definition of tunneling, it can occur even at zero field. It is just that it is highly unlikely that it will occur in that situation. So, in principle, field emission current can occur over a large range of field. It is just that, based on the type of electron detection scheme used, there may not be any significant reading until it gets to some value. This may be what they meant by the "minimum field emission current".
And erst is not correct. Fowler-Nordheim does apply to metal-vacuum interface. If not, the hundreds of papers published in accelerator physics studying high-gradient structures are all wrong. There's also nothing inherent in the FN model that demands that it must be metal-semiconductor or metal-metal interface. In fact, it is this field-emission current that is the leading cause that initiates vacuum breakdown in high-gradient accelerating structures.
Zz.
17K
