Figuring out time to center of the Earth via a vacuum hole
The problem involves calculating the time it takes for an object to fall through a vacuum hole drilled from the North to South pole of the Earth to its center. The context is rooted in gravitational physics, specifically examining motion under varying acceleration due to gravity.
  • The original poster attempts to derive the time taken for an object to reach the center of the Earth using integration and velocity as a function of position. Some participants question the recognition of the governing differential equation and its relation to harmonic motion.
Participants have engaged in clarifying the nature of the differential equation involved and its implications for the problem. There is a suggestion that the equation resembles that of a harmonic oscillator, which may provide insight into the time calculation. The discussion reflects a productive exchange of ideas without a definitive consensus on the final solution.
There is a noted discrepancy in the original poster's calculated time compared to the expected answer, prompting further exploration of the underlying physics and mathematical relationships. The problem is framed within the constraints of a homework assignment, focusing on understanding rather than providing direct solutions.
ryank614
A hole is drilled from the North to South pole. THe air is evacuated. An object dropped from the surface would accelerate at a=-gs/R(e), where s is the distance of the object from the center of the Earth. Find the magnitude of velocity at the middle of the Earth and the time in seconds required for the object to fall to the middle.
R(e)=radius of the Earth given as 6370 km.
g=9.81m/s^2
2. The attempt at a solution
I have figured out the first part.
a(s)=dv/ds * ds/dt = v * dv/ds
Using this, since acceleration is given in terms of position,
a(s) ds = v dv
Integrating with the left side from s0=6370000 meters to s1=0 AND v0=0 and v1=v,
I found the magnitude of the velocity at the middle of the Earth to be 7905 m/s
Then comes the problem. I can't seem to figure out the time it takes. This is what I have so far.
From the above integral, I found velocity as a function of position.
Using v(s) = ds/dt, I put ds/v(s) = dt.
I tried integrating this which would be
ds/SquareRoot(g*s^2/R(e)) = dt.
I get t=12630 seconds. The answer is 1266 seconds. Where did I go wrong?
Since [tex]a=-\frac{g}{R_e}s[/tex] and [tex]a=\ddot{s}[/tex] you get
[tex]\ddot{s}+\frac{g}{R_e}s=0[/tex]
Do you recognize this equation?
no sorry I don't :(
It is the harmoning oscillator equation :smile:, i.e.
[tex]\ddot{x}+\omega^2\,x=0[/tex]
with period
[tex]T=\frac{2\,\pi}{\omega}[/tex]
Ok, so you are saying the double integral of s + gs/R(e) = 0. I can't completely see how that helps me the time.
Unless, are you saying that g/R(e) is equal to w?
Yes!
[tex]\omega^2=\frac{g}{R_e}[/tex]
Now, can you figure out how much time needs the object to travel from the surface to the center?
Wow. Thank you very much. I just plugged in w and divided by 4 since it was asking for the time to the center.
Thanks!
Glad I helped! :smile:
