Find a 2x2 Matrix which performs the operation....
  • Thread starter Thread starter Jtechguy21
    Matrix
The discussion revolves around finding a 2x2 matrix that transforms the standard basis vectors e1 and e2 such that e1 maps to e2 and e2 maps to e1. Participants clarify that a single matrix must satisfy both conditions simultaneously, rather than using two separate matrices. The general form of the matrix is suggested to be examined to determine the relationships between its elements based on the requirements. Ultimately, one user concludes that the matrix can be defined by its action on the basis vectors, leading to a specific matrix representation. The conversation highlights the importance of understanding linear transformations and their matrix representations in vector spaces.
Jtechguy21
[/B]Find the matrix that performs the operation
2x2 Matrix which sends e1→e2 and e2→e1
[/B]
I know e1 = < 1 , 0>
and e2 = <0 , 1>
Basically I'm not quite sure what the question is asking. This is the one of the problems I am currently stuck on. He is teaching out of the book-currently
Can someone please explain what this means?
The problem asks you to find a matrix ##A## such that ##A e_1 = e_2## and ##Ae_2 = e_1##.
thanks. So If i understand from your clarification,
This 2x2 matrix that I'm looking for, when I multiply it by e1 it will give me e2, and vice-versa, this unknown matrix multipled by e2 will give me the result e1.
Yes.
Orodruin said:
Yes.
Thanks again.
When i find the 2 these two matrixes that perform these two operations. When I multiply them together the result should be the 2x2 matrix that this question is asking for?
No. You need to find a single matrix which satisfies both relations.
How is that even possible?
1] I found a 2x2 matrix we'll call A that when you multiply it by e1 = e2
2] I also found a 2x2 matrix B that when you multiply it by e2 =e1
But how is it possible to satisfy both conditions at the same time with the same 2x2 matrix? Any hints?
Any matrix is defined by its action on a complete basis. If you just know how it acts on a single vector you cannot determine it uniquely. I suggest assuming the most general form
$$\begin{pmatrix}a&b\\ c&d\end{pmatrix}$$
and examine what you can say about ##a,b,c## and ##d## from your requirements.
Nevermind I just figured it out. thanks for your help with adding to my knowledge/intuition with that statement about defining a matrix actions.
!(took me long enough)
The 2x2 matrix i came up with was the following.
Like Orodruin was saying, a matrix associated to a linear map T is uniquely defined by the effects of T on the given choice of basis. Then , for a map (Assummiing this, given your posts) from ##\mathbb R^2 ## to itself , both with the same basis, the associated matrix is ## [(Te_1)^T , (Te_2)^T] ##. where the T means transpose. Note that the copies of ##\mathbb R^2 ## may have different bases, then the solution is different. There are many variants, of course, of maps between vector spaces ( or even --free, of course-- rings/modules) of different dimensions, with different bases, but the idea of your case generalizes nicely here.
  • · Replies 18 ·
20K
