Find a basis for U perp given U = {(3,-1,2),(2,0,-3)}
  • Thread starter Thread starter stunner5000pt
    Basis
stunner5000pt
to find U perp i have to find a vector such that it perpendicular to BOTH of those vectors up there
3x - 2y + 2z = 0
2x - 3z = 0
i get z = t
y = 13t/2
x = 2t
so the only basis for U perp is
{2t,13t/2,t}?? ALl values of t are simply multiples of each other anyway...
AM i right? Only one vector?
Also
If R^n = span\{X_{1},X_{2},...,X_{N}\} and X \bullet X_{i} = Y \bullet X_{i}
for all i, then show that X = Y
WEll all the Xi form an orthogonal basis right? So from the given condition couldn't we say
for n not i
X \bullet \left(\frac{X_{i} \bullet X_{1}}{||X_{1}||^2} X_{1} + ... + \frac{X_{i} \bullet X_{n}}{||X_{n}||^2} X_{n}\right)
and Y \bullet \left(\frac{X_{i} \bullet X_{1}}{||X_{1}||^2} X_{1} + ... + \frac{X_{i} \bullet X_{n}}{||X_{n}||^2} X_{n}\right)
since the two are equal.. and Xi dot X and Xi dot are all equal... then X must be same as Y
Strictly speaking, {2t,13t/2,t} is not a basis for U perp, you have to pick some value for t. Also, you need to put your vector in brackets, otherwise this is just a set of 3 numbers, which has nothing to do with anything. So if you pick some non-zero t, then {(2t,13t/2,t)} is a basis for U perp.
How do you know the Xi form an orthogonal basis? And do you intend N to be the same as n? Anyways, you're overcomplicating things, and what you've written doesn't make sense, so I don't know how to help you. As a general tip, if you want to show two things are equal, a good way to do it is to show that their difference is 0. So as a start, consider the fact that since X.Xi = Y.Xi for all i, (X-Y).Xi = 0 for all i.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
