Find a Mistake in Proof: 0,1,2,3 are All Even
  • Thread starter Thread starter Demonoid
    Mistake Proof
The proof claiming that 0, 1, 2, and 3 are all even is flawed due to a misunderstanding in the induction step. The base case correctly identifies 0 as even, but the assumption that both k and 1 are even when k = 0 is incorrect. This leads to the erroneous conclusion that k + 1 (which equals 1) is also even. The key mistake lies in assuming the inductive hypothesis holds for k = 0, which fails since it does not apply to the case of k = 1. Ultimately, the induction step must be independent of the specific value of k, which this argument does not satisfy.
Demonoid
Basically I need to find a mistake in this "proof".
I claim that 0,1,2,3...are all even.
I will use induction to prove that 'n is even' for n = 0,1,2,3...
Base case is n = 0, which is true, 0 is even. I assume that the statement is true for
n = 0,1,2,3...,k and consider n = k+1. By assumption, 1 and k are both even, and thus k+1 is even as well. This means that n = 0,1,2,3... are all even.
I can't seem to find a hole in the proof. I know that 1 is not even and when we add 1 to an even number, we get an odd number. But, by assumption 1 is even, so, what do I do know ?:-p
Mathematics news on Phys.org
Try your argument when getting from k = 0 to k = 1.
If k is even, then k+1 is odd...
There is nothing wrong in you proof...wat you are doing is dat you are assigning a subscript for each even number so A0=0, A1=2...so by induction you r getting this peculiar result which is for the subscript...:smile:
As LCKurtz said, the problem is between 0 and 1. You seem to be tacitly assuming that k is greater than 1 when you say that 1 is even by the inductive hypothesis. But for k=0, this isn't true since k+1=1.
More accurately, his argument fails because he can't choose 1 and k > 1 to add together in the induction step because there is no such k.
The real lesson in this example is that in induction arguments, the induction step must be independent of the value of k, which it isn't in this argument.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
