Find all solutions to 3^a - 1 = 2b^2 - B.M.O. problem
  • Thread starter Thread starter al-mahed
al-mahed
That's a problem I saw at another math forum. It is said to be the last problem of the last phase of the national Brazilian mathematical olympiad. The case "a is even" is solved, but the case "a is odd" is resisting. I'd apreciate if you could give me any hints about it. I wrote the following proof, though I think at the end more steps are needed to give an absolute proof.
_____________________________________________________________________________
Let a = 2k+1, we have 3^{2k+1} - 1 = 2b^2 ==> 3^{2k+1} - 3 = 2b^2-2 ==>3(3^{2k} - 1) = 2(b^2-1)
so
3(3^k - 1)(3^k+1) = 2(b-1)(b+1)
of course there's 2 trivial solutions where k = 0 (a=1) and b = 1, or a = 0 and b = 0, and there is no integer k, but let's suppose that k>0
as gcd(3^k - 1,\:3^k+1) = 2 ==> (3^k - 1)(3^k+1)\equiv 0\\: mod\\: 8 ===> b is odd ==> b = 2n+1 ==>
b^2 = 4n(n+1)+1 ==>\: 3^{2k+1} - 1 = 2[4n(n+1)+1] ==>\: 3^{2k+1} = 8n(n+1)+3 ==>
==>\: 3^{2k} = (3^k)^2=\frac{8n(n+1)}{3}+1 since (3^k)^2 is a perfect odd square, then
(3^k)^2 =\frac{8m(m+1)}{2}+1 =\frac{8n(n+1)}{3}+1==>\: 3m(m+1)=2n(n+1) where m is a given positive integer
that's certainly false, I've tried to prove it but seems to be really tricky
It is obvious that \frac{n(n+1)}{3} cannot be a triangular number, but it is so obvious that I cannot solve it in a simple manner.
The case of a=5, gives b=11. We then have, k=2, n=5, which fulfills 3^(k^2) = 8n(n+1)/3 +1, or 81= 8*5*6/3+1 or 81= 80+1.
For triangle number 10, we have 10 = 4*5/2 = 5*6/3.
Yes, you're absolutely correct! This small example skipped me. But is it the only one? Perhaps there is another easier way to find the solution.
In fact \frac{n(n+1)}{3} can be triangular infinitely many times, what I was trying to say is that when it is triangular the square \frac{8n(n+1)}{3}+1 is not only divisible by 3, or maybe it is not divisible by 3 at all (perhaps 10 is the only solution).
I think this way to prove it is too complicated.
thank you for your imput
Unfortunately trying small cases doesn't really uncover a pattern (which makes this a olympiad problem I guess). For diophantine equations, if using clever factorizations or inequalities to force solutions doesn't work, then perhaps try some more advanced tools. You could try converting this to a "[URL equation[/URL] and consider a convenient mod to uncover solutions. I haven't tried that yet, but I haven't found an elegant way to do this.
Thank you for your hints, in fact I was trying a different strategy now:
lets write the equation as \frac{3^a-1}{3-1}=b^2
we already demosntrated that if a=2k+1 then b=2n+1, so
==> \frac{3^{2k+1}-1}{3-1}=1+3+9+...+3^{2k}=(2n+1)^2=4n(n+1)+1 ==>
==> 1+3+9+...+3^{2k}=4n(n+1)+1 \ ==> \ 3+9+...+3^{2k}=4n(n+1)
there are 2k terms on the sum at the left
rewriting
(3+9)_1+(27+81)_2+...+(3^{2k-1}+3^{2k})_k=4n(n+1)\ ==>
\ ==> \frac{(3+9)_1}{4}+\frac{(27+81)_2}{4}+...+\frac{(3^{2k-1}+3^{2k})_k}{4}=n(n+1)
if we notice that 3^r+3^{r+1}=3^r(3+1)=4*3^r then we can write the above as
\ ==> \frac{3^1(1+3)_1}{4}+\frac{3^3(1+3)_2}{4}+...+\frac{3^{2k-1}(1+3)__k}{4}=n(n+1)
cancel 1+3 with 4, we have
(3^1)_{1}+(3^3)_{2}+...+(3^{2k-1})_{k}=n(n+1)
we notice that n(n+1) is even, so as there are k terms on the sum at the left, and the terms are all odd, then k is even, because an odd quantity of odd numbers added is an odd number, so we must have an even number of terms, so k is even, let's call k = 2x
from here, we conclude that as a = 2k+1 = 4x+1, obviously a is of the form 4x+1 and we can factor the equation as follows
3^{4x+1}-1=2b^2 \ ==> \ 3^{4x+1}-3=2b^2-2 \ ==> \ 3(3^{4x}-1)=2(b^2-1) \ ==>
\ ==> \ 3(3^{2x}-1)(3^{2x}+1)=2(b-1)(b+1) \ ==>
\ ==> \ 3(3^x-1)(3^x+1)(3^{2x}+1)=2(b-1)(b+1)=2(2n)(2n+2)=8n(n+1)
as (3+9)_1+(27+81)_2+...+(3^{2k-1}+3^{2k})_k=4n(n+1) therefore
\ ==>\ 2[(3+9)_1+(27+81)_2+...+(3^{2k-1}+3^{2k})_k]=3(3^x-1)(3^x+1)(3^{2x}+1)
arranging the terms at the left properly, and noticing that 2 = 3^1-1
(3^1-1)[3^1(1+3^1)_{1}+3^3(1+3^1)_{2}+...+3^{2k-1}(1+3^1)_{k}]=3(3^x-1)(3^x+1)(3^{2x}+1)
(3^1-1)(3^1+1)[3^1_{1}+3^3_{2}+...+3^{2k-1}_{k}]=3(3^x-1)(3^x+1)(3^{2x}+1)
as k is even = 2x, we can line up the powers of 3 two-by-two again, and I'll now insert 2x where there is k written
(3^1-1)(3^1+1)[(3^1+3^3)_{1}+(3^5+3^7)_{2}+...+(3^{4x-3}+3^{4x-1})_{x}]=3(3^x-1)(3^x+1)(3^{2x}+1)=
=(3^1-1)(3^1+1)[3^1(1+3^2)_{1}+3^5(1+3^2)_{2}+...+3^{4x-3}(1+3^2)_{x}]=3(3^x-1)(3^x+1)(3^{2x}+1)=
(3^1-1)(3^1+1)(3^2+1)[3^1_{1}+3^5_{2}+...+3^{4x-3}_{x}]=3(3^x-1)(3^x+1)(3^{2x}+1)=
3(3^1-1)(3^1+1)(3^2+1)[3^0_{1}+3^4_{2}+...+3^{4x-4}_{x}]=3(3^x-1)(3^x+1)(3^{2x}+1)
so we have x terms there, the equality suggests that x = 1, but I cannot see how to proceed from here, any ideas?
best regards
I asked online questions about Proposition 2.1.1: The answer I got is the following: I have some questions about the answer I got. When the person answering says: ##1.## Is the map ##\mathfrak{q}\mapsto \mathfrak{q} A _\mathfrak{p}## from ##A\setminus \mathfrak{p}\to A_\mathfrak{p}##? But I don't understand what the author meant for the rest of the sentence in mathematical notation: ##2.## In the next statement where the author says: How is ##A\to...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
