Find CFM Formula: Pipe Diameter & PSI
  • Thread starter Thread starter shellback
    Cfm Formula
5 replies · 17K views
shellback
I just want the formula that shows how to find for CFM. I have the pipe diameter and the PSI that are available. I'm just using air, nothing special.
Can you be more specific with what you want to know? I presume you mean how to determine the flow rate of air in cubic feet per minute through a pipe when knowing only the pipe diameter and back pressure?
CS
CS
Yes, that's exactly right. I know there's a way to do it. I just haven't been able to work that out.
The pressure is the static pressure in the pipe? That isn't enough to determine the airflow. You need a differential pressure across an orifice, pressure drop in a venturi or velocity pressure from a pitot tube.
Once you get some form of velocity pressure (and if you give us more details about your setup, we can tell you how to measure/estimate it), you can use a form of Bernoulli's equation to find the velocity:
V=4005*sqrt(Vp)
where
V= velocity in fpm
Vp= velocity pressure in inches of water gauge.
We're going to have a compressor maintaining a constant pressure of +100psi regulated to 100psi and a 3/8" ID for the pipe at its' most narrow.
That's static pressure. It doesn't have anything directly to do with velocity (consider an air tank pressurized to 100psi: no airflow at all). What is this pipe supplying? Or is it open ended?
