Find how far the spring will be stretched
  • Thread starter Thread starter ShelbyMcD
    Spring
To determine how far a spring will stretch under a force of 0.54 N, the spring constant (k) must first be calculated using the initial force of 0.80 N and the distance of 0.012 m. The formula F = kΔd allows for the calculation of k as k = F/Δd, which simplifies to k = 0.80 N / 0.012 m. Once k is found, it can be used to find the new stretch distance by rearranging the formula for the new force. The discussion highlights the importance of understanding the relationship between force, spring constant, and displacement in solving spring-related problems.
ShelbyMcD
A spring is stretched by a force of 0.80n a distance of 0.012m. Find how far it will stretch when the force is 0.54n.
One problem is that I don't know how to find k.
F=kΔd
F=kΔd
F=k(0.012m)
What is k?
F=kΔd
so
k = F/Δd
Wow...
I can't believe I didn't think of that. Thank you!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
