Find IC Package Specs: Dimensions, Pitch & More
  • Thread starter Thread starter Jiggy-Ninja
    Ic Resource
Online resources for finding physical specifications of various IC packages, including dimensions and pitch, are essential for comparing SMT varieties like SOT-108, SOT-337, and SOT-402. Users express frustration over the lack of clear differentiation in product images and the difficulty in accessing comprehensive datasheets that include CAD drawings and suggested footprints. A recommended resource is the Texas Instruments package guide, which provides useful links for further exploration. However, it's important to note that manufacturers may not consistently adhere to specifications, making verification against specific datasheets necessary. Utilizing these resources can streamline the shopping process on platforms like Mouser and Digikey.
Jiggy-Ninja
Is there some place online where I can find physical specs (dimensions, pitch, etc) for various IC packages, especially all the jillions of SMT varieties, so I can easily compare them?
I'm doing some shopping on Mouser/Digikey, and I don't have any easy way of knowing what the differences are between things like SOT-108, SOT-337, and SOT-402 (which all look the same in the pictures), or if there even are any significant differences.
That's quite annoying, no? You should be able to flip through to the end of the datasheet for package dimensions (CAD drawing of the IC along with the dimensions). Sometimes, you can even see suggested footprints (those these are really quite rare).
The following page (and some of the ones linked to on the left-hand column) may be of benefit. Keep in mind, different manufacturers often have a nasty habit of not always following each-others specs, so always verify footprints against specific datasheets.
http://www.ti.com/sc/docs/package/guide.htm
The obligatory Wikipedia / Wikia pages that may be of some benefit:
http://en.wikipedia.org/wiki/Chip_carrier
http://en.wikipedia.org/wiki/Integrated_circuit_packaging
http://en.wikipedia.org/wiki/List_of_chip_carriers
http://how-to.wikia.com/wiki/Howto_identify_chip_packages
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
67K
