Find Magnitude & Direction of Force P for Friction Question
  • Thread starter Thread starter snshusat161
    Friction
The discussion revolves around a physics homework problem involving two blocks on an inclined plane and a horizontal surface, focusing on calculating the magnitude and direction of a force P required to initiate motion. Participants explore the equations of motion, frictional forces, and the relationship between the angle θ and the force P.
  • Homework-related
  • One participant presents the problem and initial calculations, expressing uncertainty about the angle θ needed for further calculations.
  • Another participant asks for the equations derived from the problem to better understand the approach taken.
  • A participant describes the forces acting on block A and block B, providing equations for normal force and tension, but acknowledges the need for the angle θ to solve for force P.
  • Some participants suggest substituting variables to simplify the equations, indicating a method to express the relationship between P, θ, and other forces.
  • There is a correction regarding the angle θ, clarifying that it is not 60 degrees but rather the angle made by force P on the horizontal.
  • One participant notes that the derived equation allows for multiple values of θ, each corresponding to a unique value of P, raising the question of which θ minimizes P.
  • A later reply suggests that the minimum value of P occurs when the sine function is maximized, indicating a relationship between θ and the sine function.
  • Another participant expresses gratitude for the explanation but uses informal language, indicating a casual tone in the discussion.
Participants do not reach a consensus on the value of θ or the final expression for P, as multiple interpretations and approaches are presented. The discussion remains unresolved regarding the exact calculations and relationships between the variables.
There are unresolved assumptions regarding the angle θ and its impact on the calculations. The discussion reflects varying interpretations of the problem setup and the equations derived from it.
snshusat161
Two rectangular blocks of weight, A = 150 N and B = 100N are connected by a string and rest on an inclined plane and on a horizontal surface as shown in the figure. The coefficient of friction for all contiguous surfaces is [tex]\mu[/tex] = 0.2. Find the magnitude and direction of the least force P at which the motion of the block will impend.
frictional force = [tex]\mu[/tex]. N
where N = normal rection
I had calculated T In the string from box A and then I have made two equations from box B. The only think I am unable to find is the angle [tex]\theta[/tex]. Somebody help me to find that angle.
Answer: P = 161.7 N and [tex]\theta[/tex] = 11.31 degree
sorry for the poor diagram. I don't have a scanner.
Well what two equations did you get?
Hard to show me in the diagram but I know you all can understand cause you all are very well known to such resolution of forces. So I'm proceeding directly without any diagram.
For body A
N = 150 cos 60 = 75 N
T =[tex]\mu[/tex] N + 150 sin 60
= 145 N
For body B
R + P sin[tex]\theta[/tex] = 100 ......(i)
[tex]\mu[/tex] R + 145 = P cos[tex]\theta[/tex]
= 0.2 R - P cos[tex]\theta[/tex] = -145 ...(ii)
Now I can solve this two equations and can calculate the value of P if I know value of [tex]\theta[/tex]. I want your help.
bump!
hi snshusat161! :smile:
(have a mu: µ and a theta: θ :wink:)
subtitute for R from (i) into (ii), and your equation should be of the form P(Acosθ + Bsinθ) = C …
now write Acosθ + Bsinθ as a multiple of cos(θ+φ), for some φ :smile:
then I will have 1.01P Cos ([tex]\theta[/tex] - 78.96) = 165
and still i have two unknowns and only one equation. :confused:
that 60 degree is not the value of [tex]\theta[/tex]. It is unclear in diagram but [tex]\theta[/tex] is the angle made by force P on the horizontal. (block A).
For body A
= 145 N
For body B
Sorry, I made a mistake here.
Here's the correct one
For body B
= 145 N
For body A
(just got up :zzz: …)
(what happened to that θ i gave you? :confused:)
ok, if that was the correct equation, what it would tell you?
it says that you can get the desired motion for different values of θ, and for each value of θ there's only one value of P …
but for what value of θ is that value of P a minimum? :smile:
sorry it was sine not cosine. so p will be minimum for max value of sine. i.e theta minus phi is equal to ninety. thanks tiny tim you really explained me in a very interesting nice and smart way.
i am on phone so I'm inclined to use texting language. please ignore if you feel that my posts are breaking any rules.
