Mathematica Find Max & Min Y-Axis Values on 2D Plots with Mathematica
  • Thread starter Thread starter natski
    Mathematica
The discussion centers on using Mathematica to determine the maximum and minimum y-axis values of a 2D plot. The user encountered issues with the Maximize function, which incorrectly identifies imaginary parts in their function, despite it being plot-ready. They found that FindMaximum provides a satisfactory numerical estimate instead. Additionally, there are inquiries about hiding lengthy calculation outputs in Mathematica. Suggestions include using the Short function to limit output visibility or placing a semicolon at the end of a statement to suppress output. The user also seeks advice on printing plain text messages during calculations, expressing a need for messages like "10% complete" to update dynamically. The Print function is identified as a potential solution for displaying these messages.
natski
I wanted to know whether it was possible for Mathematica to give you an exact read out of the maximum and minimum y-axis values on a 2D plot?
I have tried Maximize function but it seems to think there are imaginery parts in my function (which there are not or how would it plot the function in the first place) and so refuses to work out the maximum.
What I'm looking for is a way to plot the graph and then simply read off the max and min values with speed and accuracy.
Thanks
Natski
Maximize should work. Perhaps you should provide us with the function you're trying to work with.
- Warren
Sorry I can't supply you with the function, but suffice to know that maximize does not work because it thinks the function has imaginery parts depsite the fact I implicity select Maximize[Re[f],x]. However, FindMaximum does seem to give a good numerical estimate.
As an aside on forming 'programs' in Mathematica, I want to hide a calculation output since it's several pages long and completely useless to see the result anyway. Is there a way of 'hiding' the result of a calculation from view?
I think there are 2 things here.
One if the output is too long you could use the Short function(something like:
Code:
Short[your_function,number_of_lines_you_want_to_see]
or maybe the Shallow function (don't really remember how that works).
If you don't whant to se the out put it might be good to use := instead of =
As for really hiding the output I never heard of a way aldo that doesn't mean there isn't one.
IIRC, to hide the output, simply put a semi colon at the end of the statement.
Excellent, thank-you very much Fred. I don't suppose I could trouble you also on how you create a text message? I've tried Print, StylePrint, Message,etc but they all seem to want to print expressions rather than just plain text.
Natski
I actually think I may have stumbled across the solution myself, I think it's Print["text here"]
Maybe you could try the ToString function (checkout: http://documents.wolfram.com/v4/RefGuide/ToString.html" for more information).
I think the Print function works fine for my purposes. I'm have 10 parts to a lengthy calculation and I simply want to print out '10% complete', etc at each part of the calculation. What would be really useful is if when '20% Complete' message appears it automatically replaces the '10% Complete' message. Is that possible?
Natski
24K
