MHB The Magic of Algebra: Solving Word Problems with Equations
  • Thread starter Thread starter mathdad
The discussion revolves around solving a word problem involving the cost of apples, pears, and oranges using algebraic equations. Participants set up equations based on the relationships provided: three apples equal four pears and three pears equal two oranges. By manipulating these equations, they derived that 81 apples cost the same as 72 oranges. The conversation highlights the challenge of translating word problems into equations and the satisfaction of arriving at the correct solution. Ultimately, the discussion emphasizes the elegance and utility of algebra in problem-solving.
mathdad
Three apples cost as much as 4 pears. Three pears cost as much as 2 oranges. How many apples cost as much as 72 oranges?
Is this a proportion set up?
If so, can you set it up?
Mathematics news on Phys.org
The way I would go about this one is to let P be the cost of a single pear, A be the cost of a single apple, and O be the cost of a single orange. From the information provided, we may state:
$$3A=4P$$
$$2O=3P$$
Now, we want to relate apples and oranges, so I would multiply the first equation by 3, and the second equation by -4, and add the equations, which will eliminate P, and result in an equation relating apples to oranges. At that point, you want 72O on one side, which will tell you how many apples are equivalent in price to 72 oranges.
$$3A=4P$$
$$2O=3P$$
I did as you suggested and got 144 apples.
I then divided 144 by 3 and 48 apples.
The choices for the number of apples are 36, 48, 64, 81.
In the back of the book, the explanation is tricky and reveals the answer to 81 apples.
Here is the explanation according to the author:
Let A = cost of 1 apple.
Let P = cost of 1 pear.
Let (Or) = cost of 1 orange.
(1) 3A = 4P So, P = (3/4)A Substitute into (2) below.
(2) 3P = 2(Or)
(2a) 3(3/4)A = 2(Or) Divide both sides by 2.
(Or) = (9/8)A Multiply both sides by 72.
72(Or) = 72(9/8)A
72(Or) = 81A
So, 81 Apples cost the same as 72 Oranges.
I was seeking an easier explanation than the book's solution.
(2) 3P = 2(Or)
72(Or) = 72(9/8)A
72(Or) = 81A
I was seeking an easier explanation that the book's solution.
I also got 81 apples...here's what I did:
$$3A=4P$$
$$2O=3P$$
$$9A=12P$$
$$-8O=-12P$$
Adding the equations, we get:
$$9A-8O=0$$
or:
$$9A=8O$$
We want 72O on one side, so multiply through by 9:
$$81A=72O$$
So, we find 81 apples costs the same as 72 oranges. :D
$$3A=4P$$
$$2O=3P$$
$$9A=12P$$
$$-8O=-12P$$
$$9A-8O=0$$
or:
$$9A=8O$$
$$81A=72O$$
You just demonstrated the beauty of algebra. To take a tricky application and translate it to equations leading to the answer is the true work of a mathematician. Not too many people can reason this way.
If I could master this art of solving word problems by translating words to equations, I probably would be working for Kaplan, Sylvan, Princeston and/or other prestigious tutoring companies making tons of money. Tutoring is better than classroom teaching. Algebra is true magic.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
16K
