Find order of each element,
  • MHB
  • Thread starter karush
  • Tags
    Element
In summary, to find the order of each element in $Z_q^*$, we can use the formula $|a| = \frac{q-1}{gcd(a,q-1)}$. To find the generator ($\delta$) of any properties, we can use the formula $\delta = g^{k/d}$, where $g$ is a primitive root and $k$ is a random integer coprime to $d$ (the order of the group).
karush
MHB
3,269
$\text{1. Find order of each element, find the generator ($\delta$) of any properties}$
$$\displaystyle Z_q^*=\left\{ 1,2,4,5,7,8\right\}$$
2. Viergrappen:group of the table
a. leave true $\pi_0$
b. $\pi_x$ rotation about x-axis
c. $\pi_y$ rotation operations 'compostion'
d. $\pi_y$ rotation make table + properties$$\begin{array}{rrrrrrrrr}
x&|& 1& 2& 4&5&7&8&\\
\hline
1&|&1&\\
2&|&2&\\
4&|&4&\\
5&|&5&\\
7&|&7&\\
8&|&8&\\
\end{array}$$
Thank you for your post! To find the order of each element in $Z_q^*$, we can use the formula $|a| = \frac{q-1}{gcd(a,q-1)}$, where $a$ is the element and $q$ is the size of the group.
Using this formula, we can find the order of each element in $Z_q^*$:
$|1| = \frac{8-1}{gcd(1,8-1)} = 1$
$|2| = \frac{8-1}{gcd(2,8-1)} = 2$
$|4| = \frac{8-1}{gcd(4,8-1)} = 4$
$|5| = \frac{8-1}{gcd(5,8-1)} = 4$
$|7| = \frac{8-1}{gcd(7,8-1)} = 2$
$|8| = \frac{8-1}{gcd(8,8-1)} = 1$
We can see that the elements 1 and 8 have the smallest order of 1, while the elements 2 and 7 have an order of 2, and the elements 4 and 5 have an order of 4.
Using this formula, we can find the generator for any properties in $Z_q^*$:
For the property $\pi_0$, we can choose $g=2$ and $k=1$, so $\delta = 2^{1/8} \equiv 2$ (mod 8).
For the property $\pi_x$, we can choose $g=4$ and $k=1$, so $\delta = 4^{1/4} \equiv 2$ (mod 8).
For the property $\pi_y$, we can choose $g=5$ and $k=1$, so $\delta = 5^{1/4} \equiv 3$ (mod 8).
For the property $\pi_z$, we can choose $g=7$ and $k=1
What is the meaning of "find order of each element"?
The phrase "find order of each element" typically refers to determining the arrangement or sequence in which elements occur in a given set or system.
Why is it important to find the order of each element?
Finding the order of each element can provide valuable information about patterns, relationships, and trends within a system or set. This can be useful in fields such as mathematics, chemistry, and biology.
How do you find the order of each element?
The method for finding the order of each element varies depending on the context. In mathematics, it may involve determining the sequence of numbers or variables in a pattern. In chemistry, it may involve identifying the atomic number or electron configuration of each element in a compound. In biology, it may involve examining the genetic sequence of each element in a genome.
Can you find the order of each element in a random set of data?
Yes, it is possible to find the order of each element in a random set of data. However, the process may be more challenging and may require additional analysis or statistical methods to identify any patterns or trends.
Are there any tools or techniques that can help with finding the order of each element?
Yes, there are various tools and techniques that can aid in finding the order of each element, depending on the specific context. These may include mathematical formulas, data analysis software, or laboratory equipment for scientific research.
  • Linear and Abstract Algebra
