Find relation equation between a,b
  • Context: MHB
  • Thread starter Thread starter Albert1
    Relation
The discussion revolves around finding a relationship between the parameters \(a\) and \(b\) in the context of two equations involving a variable \(x\), where \(x\) is specified as a negative integer and \(y\) as a positive integer. The focus is on deriving a relative equation and identifying pairs of \((x,y)\).
  • Exploratory, Technical explanation, Homework-related
  • Participants present two equations: \(y=x^3-ax^2-bx\) and \(y=ax+b\), seeking a relationship between \(a\) and \(b\).
  • There is a request for pairs of \((x,y)\) that satisfy the given conditions.
  • Some participants inquire about the co-primality of \(x^3\) and \(1+x\), suggesting a connection to the problem's context.
  • One participant references Euclid's algorithm in response to the co-primality question.
The discussion includes multiple inquiries and responses, but there is no consensus on the relationship between \(a\) and \(b\) or the pairs of \((x,y)\). The co-primality question also introduces a separate line of inquiry that remains unresolved.
The discussion does not clarify the assumptions regarding the values of \(a\) and \(b\), nor does it resolve the mathematical steps needed to derive the relationship between them. The implications of the negative integer condition for \(x\) and the positive integer condition for \(y\) are also not fully explored.
Albert1
$y=x^3-ax^2-bx---(1)$
$y=ax+b---(2)$
$a,b\in R$
$x$ is a negative integer, $y$ positive integer
(1) find the relative equation between $a$ and $b$
(2)pair(s) of $(x,y)$
Mathematics news on Phys.org
$y=ax+b---(2)$
$a,b\in R$
we have $y=x^3- ax^2-bx = x^3 - x(ax+b) = x^3-xy$ using (2)
or $y+xy = x^3$
or $y = \frac{x^3}{1+x}$
now $x^3$ and (1+x) are co-primes and 1 + x is not a factor of $x^3$ unless $1+x = \pm 1$
and $1+x=1$ gives x = 0 which is not admissible
so $1+x = -1$ hence $x = -2 $ and $y=8$ so this is the solution as it satisfied x -ve and y + ve
putting in (2) we get
8 = -2a + b or $2a-b = -8$ is the relationship between a and b
or $y+xy = x^3$
8 = -2a + b or $2a-b = 8$ is the relationship between a and b
How do you know $x^3$ and $1+x$ are co-prime?
because $x^3+1 = (x+1)(x^2-x + 1)$
so $x^3 = (x+1)(x^2-x+1) + 1$
so $GCD(x^3, x + 1) = GCD(- 1,x +1) =1$ or -1 if you like it and hence co-primes unless $x +1 = \pm 1$
Euclid's algorithm; ok thanks
  • · Replies 22 ·
