Find the arc length of the curve (Polar)
The discussion revolves around finding the arc length of a curve defined in polar coordinates, specifically using the equations x(t)=arcsint and y(t)=ln(sqrt(1-t^2)). The user initially struggles with the integration limits and the calculations, particularly in applying the correct limits of integration from 0 to 1/2. Corrections are made regarding a missed negative sign in the integral and the proper handling of logarithmic expressions. Ultimately, the user arrives at the correct solution, which involves simplifying logarithmic terms and acknowledges the importance of careful calculations in integral problems. The conversation highlights common pitfalls in solving arc length problems in polar coordinates.
mathnoobie
I was wondering if I did this problem correctly as I don't have the solution, also wanted to make sure that my limits of integration were correct as they tend to be tricky in finding arc length in polar coordinates.
x(t)=arcsint
S= integral from a-b of
sqrt((dx/dt)^2+(dy/dt)^2)dt
(dx/dt)^2=1/(1-t^2)
(dy/dt)^2=t^2/(1-t^2)^2
adding (dx/dt)^2+(dy/dt)^2
I get 1/(1-t^2)^2
Put all of this into the square root as said by the formula
I simplified it to the integral from 0 to 1/2 of dt/(1-t^2)
Factoring the bottom I get dt/((1-t)(1+t))
by Partial Fractions I get
2 separate integrals
(1/2)∫dt/(1-t)+(1/2)∫dt/(1+t)
Finally integrating this I get
(1/2)(ln(1-t)+ln(1+t))
Plugging in my limits of integration I get
(1/2)(ln(1/2)+ln(3/2))
Using the log rule
I get ln(3/4)^(1/2)
Thank you so much to anyone who read through this long problem!
x(t)=arcsint
(dx/dt)^2=1/(1-t^2)
I get 1/(1-t^2)^2
Using the log rule
I get ln(3/4)^(1/2)
You missed a minus sign in the first integral.
What are the limits a, b?
ehild
ehild
Ah yes you're right. I always make those negative sign mistakes. As for the limits, I'm not 100% sure what they are but it says the curve is defined by the interval 0≤t≤1/2
so I assumed they're 0 to 1/2.
Another mistake I just saw, I never plugged in 0 into my log functions.
Alright going back and fixing my mistakes.
using the fundamental theorum of calculus, I have.
(1/2)(-ln(1/2)+ln(3/2)+ln(1)-ln(1))
=(1/2)(ln(1/2)^(-1)+ln(3/2)
On a side note, (1/2)^(-1)=2 right?
If so I end up with
ln(3)^(1/2)
Why didn't you simplify -ln(1-t)+ln(1+t)?
ln(1/2)^(-1) means the reciprocal of ln(1/2) and not the logarithm of the reciprocal of 1/2. Write ln[(1/2)^(-1)]. And yes, (1/2)^(-1)=2. And do not forget the closing parenthesis from (1/2)(ln(1/2)^(-1)+ln(3/2))
If you meant \sqrt{\ln(3)} then your solution is correct now.
ehild
ehild
I didn't simplify because I was unsure of the effect of the - in front of ln, so I didn't continue with something I was unsure of to avoid mistakes early on.
Thank you so much though for taking the time to help me!
Remember, ln(y)-ln(x)=ln(y/x). It appears quite often in case a definite integral.
ehild
  • · Replies 105 ·
