Find the coordinates of a point in 3-space
  • Thread starter Thread starter CaliforniaRoll88
    Coordinates Point
The discussion revolves around finding the coordinates of a point B in 3-space given the vector A and the distance between points A and B. The vector A is defined as ##\vec A=\{6,-2,-4\}##, and the unit vector direction for B is given by ##\hat a_B=\{\frac{2}{3},-\frac{2}{3},\frac{1}{3}\}##. The magnitude of vector B is determined to be ##|\vec B|=12##, leading to the coordinates of point B being ##(8, -8, 4)##. The participants also discuss the importance of correctly applying the distance formula and algebraic simplifications to avoid errors in calculations.
  • Understanding of vector notation and operations
  • Familiarity with the distance formula in three-dimensional space
  • Knowledge of quadratic equations and the quadratic formula
  • Proficiency in algebraic manipulation and simplification
  • Study vector operations in 3D space, focusing on magnitude and direction
  • Learn how to apply the distance formula for points in three-dimensional coordinates
  • Practice solving quadratic equations using the quadratic formula
  • Explore vector projections and their applications in physics and engineering
Students and professionals in engineering, physics, and mathematics who need to understand vector analysis and spatial relationships in three-dimensional space.
  • #31
CaliforniaRoll88 said:
##\left(B\frac{2}{3}-6\right)^2=\frac {4}{9}B^2-2(B\frac {2}{3})(6)+(-6)^2=\frac {4}{9}B^2-\frac{24}{3}B+36##
##\left(\frac{1}{3}B+4\right)^2=(\frac {1}{3}B)^2+2(\frac {1}{3}B)(4)+(4)^2=\frac {1}{9}B^2+\frac{4}{3}B+16##
##\left(-\frac{2}{3}B+2\right)^2=(\frac {2}{3}B)^2+2(\frac {2}{3}B)(2)+(2)^2=\frac {4}{9}B^2+\frac{8}{3}B+4##
##\frac {4}{9}B^2+\frac {4}{9}B^2+\frac {1}{9}B^2=B^2##
##-\frac {24}{3}B+\frac {8}{3}B+\frac {4}{3}B=-\frac {12}{3}B=4B##
##36+16+4=56##
##B^2-4B+56=100##
##B^2-4B-44=0##
##x = \frac {-b \pm \sqrt{b^2 -4ac}} {2a}##
##B = \frac {-(-4) \pm \sqrt{(-4)^2 -4(1)(-44)}} {2(1)}##
##B = \frac {4 \pm \sqrt{16 +176}} {2(1)}##
##B = \frac {4 \pm \sqrt{192}} {2}##
##\left(\frac{1}{3}B+4\right)^2=(\frac {1}{3}B)^2+\color{red}{2(\frac {1}{3}B)(4)}+(4)^2=\frac {1}{9}B^2+\color{red}{\frac{4}{3}B}+16##
  • #32
There is another one that escaped my previous pass.
##\left(-\frac{2}{3}B+2\right)^2=(\frac {2}{3}B)^2\color{red}{+}2(\frac {2}{3}B)(2)+(2)^2=\frac {4}{9}B^2+\frac{8}{3}B+4##
I suggest that you redo and verify each equation before you typeset it in LaTeX.
  • #33
I think it should be ##\frac 8 3 B##.
  • #34
##36+16+4=56##
##B^2-4B+56=100##
##B^2-4B-44=0##
If this was an exam, you would lose a lot of points for no particular reason.
You can use https://www.symbolab.com/ to check your calculations.
Edit :
Link
  • #35
##\left(\frac{1}{3}B+4\right)^2=(\frac {1}{3}B)^2+2(\frac {1}{3}B)(4)+(4)^2=\frac {1}{9}B^2+\frac{8}{3}B+16##
##\left(-\frac{2}{3}B+2\right)^2=(-\frac {2}{3}B)^2+2(-\frac {2}{3}B)(2)+(2)^2=\frac {4}{9}B^2-\frac{8}{3}B+4##
##-\frac {24}{3}B+\frac {8}{3}B-\frac {8}{3}B=-\frac {24}{3}B=-8B##
##36+16+4=56##
##B^2-8B+56=100##
##B^2-8B-44=0##
##B = \frac {-(-8) \pm \sqrt{(-8)^2 -4(1)(-44)}} {2(1)}##
##B = \frac {8 \pm \sqrt{64+176}}{2}##
##B = \frac {8 \pm \sqrt{240}}{2}##
##B = \frac {8 \pm \sqrt{15*16}}{2}##
##B = \frac {8 \pm 4\sqrt{15}}{2}=##
##B = 4 \pm 2\sqrt{15}=11.74597,-3.74597##
##\vec B =11.74597\{\frac{2}{3},-\frac{2}{3},\frac{1}{3}\}##
##B(7.83,-7.83,3.915)##
Finally got the answer with this method.
  • #36
PeroK said:
Note that the factor of ##\frac 1 3## is an unnecessary complication. Instead, we can look for:
$$\vec B=B\{2, -2, 1\}$$
How do you disregard the ##1/3##?
  • #37
Why do you include it?
  • #38
Let's look at two questions. Let A be any point:
a) What are the coordinates of a point a distance ##c## units from ##A## in the direction of the vector ##\vec b##?
b) What are the coordinates of a point a distance ##c## units from ##A## in the direction of the vector ##\hat b##?
  • #39
It can be done much more easily using the Post #27 and @PeroK's suggestions!
  • #40
PeroK said:
a) What are the coordinates of a point a distance ##c## units from ##A## in the direction of the ##\vec b##?
Let ##B## be any point not ##A##:
Then the coordinates of ##B## away from ##A## by ##c## units is ##B(cA_x,cA_y,cA_z)##
Is this right?
  • #41
Is this right?
That's not right at all. The point of my question was that the answers to a) and b) are the same. A direction is a direction.
  • #42
Is this right?
I suggest that you do some 2D problems so that you can draw a diagram. I think you are struggling with 3D geometry because you are struggling with the basic concepts.
  • #43
Is this right?
Hi @CaliforniaRoll88. That's not right. As suggested by @PeroK, maybe it would help you to do a 2D problem first - a diagram is then easy to draw so you can see what's happening. How about trying this:
"The vector from the origin to point ##P## is given as ##<1, 2>##, and the unit vector directed from the origin towards point ##Q## is ##{\frac 15}{<3,4>}## . If points ##P## and ##Q## are ten units apart, find the coordinates of point ##Q##.
And you might want to re-read Post #27!
Edited.
  • #44
Edited.
##\vec P=P\left<1,2\right>##
##\vec Q=Q\frac{1}{5}\left<3,4\right>##
Let ##k=\frac{1}{5}Q##
##\vec Q=k\left<3,4\right>=\left<3k,4k\right>##
##\vec P\cdot\vec Q=1\cdot3k+2\cdot4k=11k##
##\vec R## is the resultant of ##\vec P## and ##\vec Q##
Law of Cosines:
##R^2=P^2+Q^2-2\vec P\cdot\vec Q##
##10^2=5+25k-22k##
Am I headed in the right direction?
  • #45
Law of Cosines:
##10^2=5+25k-22k##
Looks good!
PS except, should have a quadratic in ##k## with a ##25k^2## term. I missed that.
  • #46
A couple of points (pun intended).
1) We want to make ##|\vec {PQ}|=10##. Knowing the resultant ##\vec P + \vec Q## doesn't help. It's possible that you might be thinking ##\vec {PQ} = \vec P + \vec Q## but that's wrong! A suitable diagram will make this clear.
2) There is (IMO) a much simpler approach. The distance between points P and Q must be 10. You are given point P(1, 2). What are coordinates of point Q in terms of k? The rest is simple!
  • #47
##10^2=5+25k-22k##
##95=3k##
##k=\frac {95}{3}##
##\vec Q=k\left<3,4\right>=\left<3k,4k\right>=\left<3\frac {95}{3},4\frac {95}{3}\right>=\left<95,126\frac {2}{3}\right>##
Is this right @Steve4Physics, @PeroK?
Edit: I am sure it's wrong.
  • #48
##10^2=5+25k-22k##
##95=3k##
##k=\frac {95}{3}##
I missed that you had ##25k## instead of ##25k^2##. You need to find some way of reducing the number of simple algebraic errors. And, you need a way of spotting them yourself.
  • #49
As a completely separate correction, it’s probably worth noting that the above is wrong. ##\vec P = \left< 1, 2 \right>##. There is no "##P##" on the right-hand side.
The magnitude of ##\vec P## is ##P = \sqrt {1^2 +2^2} = \sqrt 5##. By writing “##P\left< 1, 2 \right>##” you are multiplying ##\vec P## by ##\sqrt 5##; this gives a new vector ##\sqrt 5## times bigger than ##\vec P##.
  • #50
##10^2=5+25k-22k##
##95=3k##
##k=\frac {95}{3}##
Hi @CaliforniaRoll88. Yes, it's wrong!
You seem to be struggling and we are not looking at the original homework problem. So maybe a bit of extra help is justifiable.
Hopefully by now you have drawn a clear diagram (xy axes) with points and vectors marked, estimating the approximate position of point Q ‘by eye’.
You have correctly written (in Post #44): ##\vec Q=k\left<3,4\right>=\left<3k,4k\right>##
##\vec Q## is an ‘arrow’ from the origin to point Q. Therefore the coordinates of point Q are ##(3k, 4k)## where ##k## is some as yet unknown value.
You have 2 points P(1,2) and Q(3k, 4k). You require the distance between them to be 10. So what equation can you now write down and solve?
  • #51
##d^2=(x_Q-x_P)^2+(y_Q-y_P)^2##
##100=(3k-1)^2+(4k-2)^2##
##(a-b)^2=a^2-2ab+b^2##
##(3k-1)^2=(3k)^2-2(3k)(-1)+(-1)^2=9k^2+6k+1##
##(4k-2)^2=(4k)^2-2(4k)(-2)+(-2)^2=16k^2+16k+4##
##(3k-1)^2+(4k-2)^2=25k^2+22k+5##
@Steve4Physics, I can see that I am using the quadratic formula method. How do I employ the Law of Cosines here?
  • #52
You have repeated a line, but no matter.
No. You have used b=-1. But b=1 because the minus sign is already taken into account in the term ##a-b##.
Here's a simple example, to illustrate what you have done. We know ##(3-1)^2 = 2^2 = 4##. What you have done is:
##(3 - 1)^2 = 3^2 - (2)(3)(-1) + (-1)^2 = 9 + 6 + 1 = 16##
This is wrong! It should be:
##(3 - 1)^2 = 3^2 - (2)(3)(1) + 1^2 = 9 - 6 + 1 = 4##.
This is very important basic algebra, so you need to make sure you master it.
No. Same mistake as described above.
This expression (when corrected) must be equal to 100, This gives you a quadratic equation you can solve to find ##k##. Then you know Q##(3k,4k)## and the problem is done.
You do not need the law of cosines if you use the above method.
  • · Replies 32 ·
  • · Replies 18 ·
