Find the corresponding rectangular coordinates for the point.
To find the rectangular coordinates for the polar point (-2, 5π/3), the calculations involve using the cosine and sine functions. Initially, the incorrect signs led to the conclusion of (1, -√3), but further analysis revealed the need to adjust the signs due to the negative radius. The correct calculations yield x = -1 and y = √3, resulting in the accurate rectangular coordinates of (-1, √3). This correction clarifies the misunderstanding regarding the signs in the conversion process. The final answer is confirmed as (-1, √3).
Lebombo
Find the corresponding rectangular coordinates for the point. (-2, \frac{5\pi}{3})
x = -2cos(\frac{5\pi}{3})
x = -2cos(\frac{2\pi}{3})
x = -2* \frac{-1}{2} = 1
y = -2sin(\frac{5\pi}{3})
y = -2sin(\frac{2\pi}{3})
y = -2*\frac{\sqrt{3}}{2} = -\sqrt{3}
So the coordinate is (1, -\sqrt{3})
This is my conclusion, however, the answer I found online does not agree: (1, -2)
Am I incorrect? If so, what am I not doing correctly?
I assume that is in polar coordinates, with negative radius.
Are you sure those are equal?
Same problem. Are you sure those are equal?
y = -2*\frac{\sqrt{3}}{2} = -\sqrt{3}So the coordinate is (1, -\sqrt{3})
That online answer is wrong. Fix your signs and you will have it.
Yes, I should have mentioned the type of coordinates.
x = 2cos(\frac{2\pi}{3})
x = 2* \frac{-1}{2} = -1
y = 2sin(\frac{2\pi}{3})
y = 2*\frac{\sqrt{3}}{2} = \sqrt{3}
So the coordinate is (-1, \sqrt{3})
Like this?
Yes...(-1,√3) is the correct answer .
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 40 ·
  • · Replies 34 ·
  • · Replies 105 ·
