Find the Equivalent Impedance of the Network
The discussion revolves around finding the equivalent impedance of a network involving resistors, inductors, and capacitors. Participants explore the definitions of series and parallel connections, the impact of frequency, and the application of formulas for combining impedances.
  • One participant expresses confusion about how to approach the problem due to the absence of clear series or parallel configurations.
  • Another participant questions the understanding of series and parallel definitions, prompting a discussion on their meanings.
  • Frequency is noted as a critical factor, with one participant confirming it to be 440 Hz.
  • Formulas for converting between series and parallel combinations are mentioned, with emphasis on applying these to resistors and inductors.
  • There is a debate on whether the resistor and inductor are in series or parallel, with differing opinions on their connection based on voltage sharing.
  • One participant shares their calculations for the equivalent impedance and expresses skepticism about a textbook answer, suggesting it contains errors.
  • Another participant agrees with the calculated impedance and shares their own result, indicating a potential typo in their previous message.
  • Discussion includes a suggestion to consider different textbooks due to perceived errors in the current one being used.
Participants do not reach a consensus on the configuration of the resistor and inductor, with multiple views on whether they are in series or parallel. There is also disagreement regarding the reliability of the textbook answers.
Participants express uncertainty about the definitions of series and parallel connections, and the impact of additional components on these configurations. There are unresolved mathematical steps in the calculations presented.
This discussion may be useful for students or individuals studying electrical circuits, particularly those grappling with impedance calculations and the concepts of series and parallel connections.
rtareen
TL;DR
Problem is from Faissler's Intro to Modern Electronics Chapter 8. We are asked to find the equivalent impedance of the network. Nothing is in series or parallel so I don't know what to do.
We are asked to find the equivalent impedance of the network. Nothing is in series or parallel so I don't know what to do. We cannot use mesh equations or Thevenin's theorem because is no current or voltage source. So I have no clue.
I believe the issue here is not this particular circuit, but that you've haven't quite understood what "in parallel" and "in series" means.
What is the definition of two elements being connected in parallel?
In series?
In series?
I know in series means if a current flows through the first component, that entire current must flow through the second. Parallel is a little vague. I think they have the same voltage across them they are in parallel. But since there is no voltage source here that definition would lead to all three being in parallel. I don't know any general definition that always works. Can you teach me the definition?
It does depend on frequency of course. Is a frequency specified?
Yes 440 Hz
There are formulas for converting series combinations to parallel and vice versa. You need to apply this to R and L to obtain the series equivalent, then the combination is in series with C. The two series reactances can then be combined into one by addition.
I know the formulas, but I don't know how to tell that R and L are in series?
L and R are in parallel. First of all, find the reactance of L at 440Hz. Then do the conversion to of L and R in parallel to series elements. Then ask again about the next step!
How do you know that they are in parallel?
R and L have both their ends connected together, they share the same voltage.
Yes but doesn't having a capacitor or even an input/output wire in between disrupt that? I deleted my work it was completely off
Once you are comfortable understanding series and parallel resistance equivalents. Look at this video about how to use the substitution for series and/or parallel resistors to simplify more complex combinations of impedances. It's the same process with inductors and capacitors. Initially just call everything "Z" (Z1, Z2, Z3, etc.), some complex impedance value, and treat it like it's a resistor. After you have solved the circuit (or part of it, if you like), then you can substitute the complex value for each "Z"; like ## Z=\frac{1}{jωC} ## for a capacitor, etc.
https://www.khanacademy.org/science/physics/circuits-topic/circuits-resistance/v/circuits-part-4
rtareen said:
Yes but doesn't having a capacitor or even an input/output wire in between disrupt that? Anyways here is my work so far.
https://www.physicsforums.com/attachments/281897
This looks in the right ballpark, which I roughly estimated as 5000 + j5000. But resistance should not be negative. The next move is to connect this in series with the capacitor. So next find the reactance of the capacitor at 440Hz.
Unfortunately, the parallel combination involves conversion to admittances, adding admittances and then converting back to impedances, which is a complication for the OP. That is why I suggested just using the series-parallel conversion formulas.
Thanks. I'll use what I got but flip the sign of the real part. So ##Z_{RL} = 4540 + 4990j##. Then we compute the capacitors impedance ##Z_C = -j(1/(wC) = -j (\frac{1}{2\pi (440)(10^{-7}}) = -3620j##. Then we use
##Z_{eq} = Z_{RL} + Z_{C} = 4540 + (4990 -3620)j = 4540 + 1370j~\Omega##
However the book, which I don't trust, said the answer is 1157 -419j ohms. This book is full of mistakes though. I've already caught three. What do you think?
I like your answer better. I found 4542.5 - 1361.9j
Good work!
Edit: Oops typo: it's 4542.5 + 1361.9j
Good work!
Woohoo !
Maybe it's time for a different book?
  • Love
I'm only using this book because its supposedly used in this electronics class at my university. If you have any recommendations I wouldn't mind checking out some others.
  • · Replies 27 ·
  • · Replies 20 ·
