Find the formula for the inverse function
fazal
The function f is defined by y=f(x) = 3ln4x 0.01<=x<=1
a)Solve for x in terms of y and hence find the formula for the inverse function f^-1(x)
b)Write down the domain of f^-1
c)Plot f from x =0.01 to x=1 and than plot f^-1 on the same axes but only for domain values of x given by the range of f
d)Describe the geometric relationship that you can see between f and f^-1
plse assist as iam very confused with functions...!
fazal said:
You seem to have missed out an important section.
The rule for the inverse function is given by f^-1(x)
how to make y the subject.
I suggest that i a graph of y = f(x) over and use it to find the range of f ?
are they reflections of each other in the line y = x.??
plse assist to answer
Okay for part (a) we have:
y = 3ln(4x)
Can you solve for x?
for a)
is it this way:
x=1/4e^(y/3)
plse assist is this right?
fazal said:
for a)
is it this way:
x=1/4e^(y/3)
Yes, that is correct. So now you can write the inverse function as
f-1(x) = 1/4exp(x/3)
So, what about the domain of the inverse function?
is the domain from 0.2508<=x<=0.3489
by using 1/4 * e^(0.01/3) and 1/4 * e^(1/3)
plse assist to check
No, that is not correct.
HINT: Think about the range of f(x).
yes the range is from 0.01<=x<=1
therefore i plug into the f^-1 and got
0.2508<=x<=0.3489
0.2508<=x<=0.3489
No, that is the domain for f(x) and why would you want to plug it into f-1(x)?
i can't seem to figure out the domain...plse assist
