Find the Gravity Center of an Egg: Boaz's Assignment
To find the center of gravity of an egg, it can be suspended by a thread, allowing it to hang symmetrically to determine its balance point. Placing the egg on a table will also reveal its center of gravity, as it will naturally rest just below that point once it stabilizes. A suggestion was made to spin the egg, but this primarily relates to its center of mass rather than directly finding the center of gravity. An experiment involving inverting the egg and marking its heavy side can demonstrate how it returns to a stable position during spinning. These methods highlight the inherent stability of the egg's center of gravity in various positions.
bobo
hello,
i have an assinment that requries puting an egg directly on it gravity center.
1. how can i find it`s gravity center?
2. do you think of and way that i could do it (maybe make some kind of pocket, of a machine?)
thanks,
Boaz
how about spinning it like a top?
Nautica
How about just letting it sit on the counter? The center of gravity is inside the egg, so, it is always "on its gravity center."
good ideads but...
the real problem that i need to take the egg that hangs in the air (connected to a sting) and put it directly on a small call that the center gravity will be in the middle (without human intervntion).
nautica suggests spinning the egg... but that wouldn't give you anything wud it? besides spinning's got more to do with center of mass (rotational motion). A way to find center of gravity is to suspend it by a thread (like someone mentioned) tied around the egg so that the egg hangs symmetrically about the circle formed by the thread around it. You do this 2 ways... first when the egg is hanging straight (the way they are kept in the box. Second way would be to hang it perpendicular to the previous position (the way it stays when you place it on the table). OK>>> that gives another idea... just place the egg on the table and it'll automatically rest on a point just below the center of gravity. Once the egg stops moving (upon placing it on the table), just note the point at which it's touching the table. The center of gravity will be just above that point half way to a diametrically opposite point.
Right good idea, spinning the egg.
But try this (using a raw egg). Let it first get into equilibrium resting on the table. Then turn it upside down, rotating it 180 degrees around the longitudinal axis (so don't put it neither on it's pointy end nor on its blunt end). Get a marker and put an x on the heavy top part. Now spin it and see what the x is doing. And we observate that contrary to a spinning top, the egg turns itself back, heavy side down, during the spinning.
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
