Find the limit of (sqrt(1+x) - 1)/(cuberoot(1+x)-1) as x->0
  • Thread starter Thread starter sara_87
    Limit
The limit of (sqrt(1+x) - 1)/(cuberoot(1+x) - 1) as x approaches 0 can be evaluated by changing variables to y = sqrt(1+x). This leads to the expression [y-1]/(cuberoot(y^2) - 1), which can be simplified by rationalizing the denominator. By multiplying by the appropriate factors, the expression simplifies to (cuberoot(y^2) + 1)/(y + 1). After canceling the common factor of (y - 1), the limit evaluates to 1 as y approaches 1. Thus, the final result is confirmed to be 1.
sara_87
Find the limit of (sqrt(1+x) - 1)/(cuberoot(1+x)-1) as x-->0
Fin limit of the follwing as x tends to 0:
[sqrt(1+x)-1]/[cuberoot(1+x)-1]
using change of variables:
let y=sqrt(1+x)
so = limit (as y tends to 1): [y-1]/cuberoot(y^2)-1]
Then i got stuck.
any help woyld be v much appreciated.
Thank you.
have you done taylor series?
Yes but we have to do this by changing the variables.
Looks to me like a problem where you would want to "rationalize the denominator.
a^3- b^3= (a- b)(a^2+ ab+ b^2) so to "rationalize" ^3\sqrt{y^2}- 1, you need to multiply by ^3\sqrt{y^4}+ ^3\sqrt{y^2}+ 1. Multiplying the numerator and denominator by that will make the denominator y^2- 1. You should be able to factor a "y- 1" out of the numerator also to cancel the "y- 1" in the denominator,.
Ok so after i cancel the y-1, i get:
(cuberoot(y^2)+1)/(y+1)
so substituting the y=1, i should get limit =1
is that right?
Assuming you the calculations correctly, which you did not show, yes.
since after cancelling the y-1,this will give: (cuberoot(y^2)+1)/(y+1)=2/2=1
Thank you.
