MHB Find the maximal value of a^4b+b^4c+c^4a
  • Thread starter Thread starter lfdahl
    Value
The discussion focuses on maximizing the expression a^4b + b^4c + c^4a under the constraint a + b + c = 5, with a, b, and c being non-negative real numbers. Participants note that while there is cyclic symmetry in the variables, it does not imply complete symmetry, leading to different values for various permutations of a, b, and c. A suggested solution was initially deemed incorrect due to this misunderstanding of symmetry. The conversation highlights the importance of recognizing the specific characteristics of the function when attempting to find its maximum value. The goal remains to determine the maximal value of the expression given the constraints.
lfdahl
MHB
Let $a, b, c$ be non-negative real numbers satisfying $a + b + c = 5$.
Find the maximal value of $a^4b+b^4c+c^4a$.
Mathematics news on Phys.org
Suggested solution:
The maximal value is $256$ and is attained at $(4,1,0), (0,4,1)$ or $(1,0,4)$.
Define $f(x,y,z) = x^4y+y^4z+z^4x$. Let $a \geq b$ and $a\geq c$.
Let us prove, that $f(a+c/2,b+c/2,0) \geq f(a,b,c)$. Indeed,
\[f(a+c/2,b+c/2,0) = (a+c/2)^4(b+c/2) \geq (a^4+2a^3c)(b+c/2) \geq a^4b+2a^3bc+a^3c^2 \geq a^4b+b^4c+c^4a = f(a,b,c)\]
Now, we maximize $f(a,b,0)$, when $a+b = 5$ by using the AM-GM inequality:
$5 = a+b = (a/4+a/4+a/4+a/4 + b) \geq 5\sqrt[5]{a^4b4^{-4}}$.
Therefore, $a^4b \geq 4^4$. Equality holds at $a = 4, b=1$. Similarly we obtain other maximum triples $(0,4,1)$ and $(1,0,4)$ when maximum of $a,b$ and $c$ is $b$ and $c$. Done.
lfdahl said:
Suggested solution:
Three triples are missing solution set is $(4,1,0),(4,0,1),(0,1,4), (0,4,1),(1,4,0),(1,0,4)$
[sp]Not true: $f(4,0,1) = f(1,4,0) = f(0,1,4) = 4$. There is cyclic symmetry but not complete symmetry in the variables.
[/sp]
[/sp]
Oops my mistake. I did not realize the output is non symmetric
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
