MHB Maximum Value of Positive Integers in a Product-Sum Equation
  • Thread starter Thread starter anemone
    Maximum Value
The discussion revolves around the equation pqrst = p + q + r + s + t, where p, q, r, s, and t are positive integers. The maximum value of the largest integer among them is determined to be 5. Participants share solutions and insights, with references to an article by Michael W. Ecker that explores the conditions under which the sum of positive integers equals their product. The article states that a positive integer v can be expressed as both a sum and a product if and only if v is not prime. Overall, the thread highlights collaborative problem-solving and the sharing of mathematical resources.
anemone
MHB
POTW Director
Let $p,\,q,\,r,\,s,\,t$ be positive integers such that $pqrst=p+q+r+s+t$.
Find the maximum possible value of max $\{p,\,q,\,r,\,s,\,t\}$.
Mathematics news on Phys.org
Hello.
I have not found another way to solve the problem:p
Suppose: p >1p=\dfrac{q+r+s+t}{qrst-1}
It follows:
qrst \cancel{=} 1 \rightarrow{}q+r+s+t \ge{}4
qrst \le{}4
If \ qrst >4 \rightarrow{} p <2
Example: p=2, \ q=2, \ r=2, \ s=1, \ t=1
Therefore:
max(p) \rightarrow{} min(q)
Solution:
p=5 \ , \ q=2 \ , \ r=1 \ , \ s=1 \ , \ t=1
p+q+r+s+t=10 \ and \ pqrst=10
Note: the variables I considerate interchangeable
Regards.
mente oscura said:
Hello.
It follows:
qrst \le{}4
Therefore:
Solution:
Regards.
Thanks mente for your solution (yes, it has the correct answer) and I will wait a bit before posting the two solutions that I have to share with you and the community here...I believe others might want to take a stab at it as well.:)
Let $P = p\cdot q\cdot r\cdot s\cdot t$, and $S = p+q+r+s+t$, where $p,q,r,s,t \in \mathbb{N}$
WLOG I can choose a $p$-value and let $q,r,s,t$ all be equal to $1$. Once $p$ is fixed, I will look for the smallest possible increments of $P$ by varying $q$.
If $p = 1$ … the smallest possible values of $P$ are: $1,2,3, …$ and $S = 5,6,7,…$.
If $p = 2$ … the smallest possible values of $P$ are: $2,4,6,…$ and $S = 6,7,8,…$
It is easy to see, that $P \neq S$ for $p > 5$.
In general:
For a given $p$ the smallest possible values of $P$ are: $p, 2p, 3p, …$ and the corresponding
$S$-values are $p+4, p+5, p+6, …$.
Thus, I´m looking for integer solutions of $p$: $np = p + 3 + n, \;\; n = 1,2,3, …$
Or $ p = \frac{n+3}{n-1}$ for $n > 1$. There are exactly three integer solutions the largest of which is $5$ (for $n=2$).
I found an interesting article "When does a sum of positive integers equal their product?" by Michael W. Ecker (Math. Mag. 75 (2002) 41–47 – you can find it online if you have access to JSTOR). It gives the answer to the problem in this thread, and much more besides.
Sample result: Given a positive integer $v$, the equation $v = x_1 +x_2 + \ldots + x_n = x_1x_2\cdots x_n$ (with $n>1$) has a solution if and only if $v$ is not prime. The proof is easy enough that readers of this subforum ought to be able to find it for themselves. (Wait)
mente oscura said:
Hello.
It follows:
qrst \le{}4
Therefore:
Solution:
Regards.
In general:
Hi mente oscura and lfdahl,
Thank you for the solution and for participating in my challenge thread!:) As I have mentioned before, $5$ is the correct answer, bravo!;)
Thanks, Opalg for your reply and sharing with us what you've found.:o
Solution(Suggested by other):
Suppose $t \ge s \ge r \ge q \ge p$.
We need to find the maximum of $t$.
Since $t<p+q+r+s+t \le 5t$, then $t<pqrst \le 5t$, i.e. $1<pqrs \le 5$.
Hence, $(p,\,q,\,r,\,s)=(1,\,1,\,1,\,2),\,(1,\,1,\,1,\,3),\,(1,\,1,\,1,\,4),\,(1,\,1,\,2,\,2),\,(1,\,1,\,1,\,5)$ which leads to maximum $t$ of 5.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
