Find the Norton equivalent resistance
2 replies · 3K views · last reply
messier992
Circuit schematic with a 9 V source on the left, resistors of 20 Ω, 5 Ω, 25 Ω, 10 Ω and 60 Ω, and a 1.8 A current source, with terminals a and b on the right.
Sum of resistance in a parallel circuit: 1/Rt = 1/R1 + 1/R2...
Sum of resistance a series circuit: Rt= R1+R2...
Don't know where to go from here:
Handwritten circuit diagram of a network with resistors 20 ohm, 5 ohm, 25 ohm, 10 ohm and 20 ohm, a 1.8 A current source, terminals a and b, followed by an equals sign and a simplified circuit with a dependent voltage source aV, 5 ohm, 25 ohm, 1.8 A source, 20 ohm, and 60 + 10 = 70 ohm.
  • Handwritten circuit diagram of a network with resistors 20 ohm, 5 ohm, 25 ohm, 10 ohm and 20 ohm, a 1.8 A current source, terminals a and b, followed by an equals sign and a simplified circuit with a dependent voltage source aV, 5 ohm, 25 ohm, 1.8 A source, 20 ohm, and 60 + 10 = 70 ohm.
  • Circuit schematic with a 9 V source on the left, resistors of 20 Ω, 5 Ω, 25 Ω, 10 Ω and 60 Ω, and a 1.8 A current source, with terminals a and b on the right.
Actually, I believe this might be the solution. Is this correct?
Handwritten resistor network simplification: a 5 ohm and 20 ohm resistor in series become 25 ohm, which is combined with a 70 ohm resistor and a 25 ohm resistor, followed by a boxed result of 14.79.
  • Handwritten resistor network simplification: a 5 ohm and 20 ohm resistor in series become 25 ohm, which is combined with a 70 ohm resistor and a 25 ohm resistor, followed by a boxed result of 14.79.
    51795511_331039977514846_8117870441529344_n.jpg?_nc_cat=102&_nc_ht=scontent.fyyc3-1.jpg
Well I see you got a start and eliminated the Voltage and Current sources. However I can't tell if those sources were replaced by Shorts or Opens. Can you clarify with a better schematic?
