Find the PDF in terms of another variable
2 replies · 2K views
CivilSigma
For
$$f_x(x)=4x^3 ; 0 \leq x \leq 1$$
Find the PDF for $$ Y < y=x^2$$
So, we take the domain on x to be:
$$0\leq x \leq \sqrt y$$
and integrate:
$$ \int_0^{\sqrt y} f_x(x) dx = \int_0^{\sqrt y} 4x^3 dx$$
Do we integrate with respect to x or y? I am not sure about this part of the problem.
If we solve the integral above we get:
$$f_x(y)=y^2 ; y \leq x^2 $$
Is this approach correct?
Thank you.
"So, we take the domain on ##x## to be:"
Wait, what? The domain of ##x## is already defined, it's (0,1]. Why would you change it?
Your integral will is calculating the cumulative distribution of ##x##, the probability that ##x## is less than or equal to ##\sqrt y##. That isn't what was asked for. However ##P(X \leq \sqrt y)## = ##P(X^2 \leq y)## = ##P(Y \leq y)##. So you've calculated the cumulative distribution of ##y##. IOnce you have the CDF for ##y## you can get the ##PDF##.
Now there's a lot wrong with your concluding statement ##f_x(y) = y^2; y \leq x^2##.
- It's not ##f_x## as this is supposed to be the density of ##y##.
- As explained already, you didn't calculate a density, you calculated a CDF.
- Since ##y = x^2## and the domain of ##x## is (0, 1], the domain of ##y## is (0, 1]. The density of ##y## is not related to a particular value of ##x##.
Working with the CDF is a useful thing to do, you're just misinterpreting what every single thing in this calculation is for.
Let's say we want the CDF of ##y##, the probability ##P(Y \leq y)## for any value of ##y##, which as we said could be anything in (0, 1] based on the domain of ##x##. ##Y \leq y \iff X^2 \leq y \iff X \leq \sqrt y##. With a different definition of ##X## that last event might be (##0 \leq X \leq \sqrt y## or ##-\sqrt y \leq X \leq 0##) but X can't be negative here.
OK, so we've established that ##P(Y \leq y) = P(X \leq \sqrt y) = \int_0^{\sqrt y} 4x^3 dx##, and that should address your questions as to whether you're integrating with respect to ##x## or ##y##, and also what you've calculated here and how it relates to what you were asked for.
To summarize: You decide to calculate the cumulative distribution of Y. You want to know how many Y's fall into a given range ##(0,y]##, for any choice of ##y##. You know what X values will give you Y's in the desired range, so you know how to use the density of X to calculate that probability. And that gives you an expression for the CDF of Y.
This makes more sense.
So, we first find cumulative probability in terms of the constraint, and then differentiate to get the probability function.
So:
$$F_y(y) = y^2 ; 0 \leq y \leq 1$$
$$f_y (y) = \frac {F_y(y)}{dy} = 2y ; 0 \leq y \leq 1$$
