FInd the Vector passing thru a point and parallel to two points in a plane
kailsen
Hi,
i have three points A',B',C' and want to find a vector passing through B' and parallel to the other two points in the plane containing these 3 points.
So this how i started,
A'=(9,27,-0.6)
B'=(12,27,-6)
C'=(19,25,-8)
I found the vector AB' and AC' first.
A'B'= A'-B'
A'C'=A'-C'
Found cross product of the two resultant vector A'B' and A'C' to get a normal vector.
now using the equation a*[x – xA] + b*[y – yA] + c*[z – zA] = 0,
i found the equation of the plane that contains all these 3 vectors (A',B',C').
Assuming the equation is -48x + 30y -2z = -90.
Now i would like to get a vector (basically x,y,z) that is passing through B' and parallel to the line passing through A' and C'.
I think, finding a line passing through the origin of of the normal vector to the plane will fetch me half the answer, but how to satisfy it to be parallel to the line A'C'
Mathematics news on Phys.org
First, you statement of the problem is strange. A "vector" does not pass through a particular point. It is entirely given by its direction and length. Nor is one vector "parallel" to another though they may be "in the same direction. You may mean "find the equation of the line passing through B' parallel to the line through A' and C'".
But then I have no idea why you would go to the work of finding two distinct vectors and their dot product. The vector from A' to C' is <19- 9, 25- 27, -8- (-0.6)>= <10, -2, -7.4>. The line through B'= (12, 27, -6) in the direction of that vector is given by
x= 10t+ 12, y= -2t+ 27, z= -7.4t- 6.
kailsen said:
Hi,
A'=(9,27,-0.6)
B'=(12,27,-6)
C'=(19,25,-8)
A'B'= A'-B'
A'C'=A'-C'
The line you want can be expressed in parametric form (s is parameter) as B' + s(A'-C').
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
