Findin acceleration with mass given
  • Thread starter Thread starter afg_91320
    Acceleration Mass
To find the acceleration of a system with three blocks (masses of 0.25 kg, 0.50 kg, and 0.25 kg) connected by strings over a frictionless pulley, one must establish equations based on Newton's laws. The setup involves one block on a table and two hanging blocks, with tensions acting on each mass. By labeling forces and choosing a positive direction for motion, three equations can be derived that relate the tensions and accelerations of the blocks. Eliminating the tensions leads to a formula for acceleration: a = (m(3)g - m(1)g) / (m(1) + m(2) + m(3)). Understanding the connections between the masses is crucial for correctly applying these principles to solve the problem.
afg_91320
Assuming ideal frictionless condition for an apparatus (a table with a block in the middle and one hanging from each side, what is: the accelerarion of the system if the mass for each is .25 kg .50 kg and .25 kg (mass 1,2, and 3 respectivley) mass 3 is on the top and mass 2 is hangin on the right side while mass 1 is on the left
I don't know how to find it and I've been tryin all day
I'm lost please help
Since you have three blocks each attached by a string, you will have three different equations with which you can manipulate to solve for acceleration. First off, draw a picture and label all the forces acting on each block and label each tension. I assume that the rope connecting the block on the table passes over a frictionless pulley when connected to the hanging block on both sides. You then arbitrarily choose a direction for which you think the system will move. Logically you should pick motion to the right to be the positive direction. Therefore all the forces you labeled that point in this direction will be positive. After all this is done, you should be able to find three equations describing the motion of the system:
m(3)g-T(2)=m(3)a
T(1)-T(3)=m(2)a
T(4)-m(1)g=m(1)a
I let the mass on the left be m(1), the mass on the table be m(2), and the mass on the right be m(3). The tension pointing up from the left block is T(4), the tension pointing left of m(2) is T(3), the tension pointing right of m(2) is T(1), and the tension pointing up from m(3) is T(2). Since the pulley is frictionless, T(4)=T(3) and T(1)=T(2). From this you get:
T(3)=T(1)-m(2)a
T(4)= m(1)a+m(1)g
T(2)=m(3)g-m(3)a
You can then eliminate the tensions and solve for acceleration by:
T(1)-m(2)a=m(1)a+m(1)g
m(1)a+m(2)a+m(1)g=m(3)g-m(3)a
m(1)a+m(2)a+m(3)a=m(3)g-m(1)g
a=(m(3)g-m(1)g)/(m(1)+m(2)+m(3))
If I interpret the situation right, the masses 1 and 2 are connected to the mass 3. I'm I right? If so, all you need is Newton's second and third laws and you can find the acceleration.
Edit: Looks like w3390 was faster...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
