Finding a formula of a math problem
  • Thread starter Thread starter laker_gurl3
    Formula
The discussion revolves around finding a formula for A, which is proportional to x^2 and inversely proportional to (y-a)^3, given that A = 1 when x = 1 and y = 0. Participants clarify that to express A as a function of x and y, one should start with A = kx^2/(y-a)^3, where k is a constant. By substituting the known values into the equation, it becomes clear that k can be determined as k = -a^3. The final formula for A is thus A = -a^3x^2/(y-a)^3. This approach effectively combines proportional relationships to derive the desired equation.
laker_gurl3
i don't know what to do for this question, what does it mean by A = 1 when x = 1 and y = 0 ? do i just sub it in or what? is this some sort of equation in an equation thingy?
The quantity A is proportional to X^2 and inversely proportional to (y-a)^3
Find a formula for A given that A = 1 when x = 1 and y = 0
Please post such questions in the Coursework Forum, not here !
First write A as a function of (x,y) using arbitrary constants. For instance if told that V is proportional to I, you can write the equation V=kI, where k is some constant.
Next you are told that when you substitute the given values of x and y, you get a certain value of A. This helps determine the value of such a constant. In my example, if told that V = 5 when I = 2, I have 5 = 2k, which tells me that k=2.5. So my Original equation can be becomes V = 2.5I
okay after following ur example, i have A=x^2, it's the inversely proportional part that i can't understand...
If you are told that A is inversely proportional to some z, then that is the same as saying that A is proportional to 1/z. Or A = k/z, where k is some constant.
"The quantity A is proportional to X^2 and inversely proportional to (y-a)^3"
A is "proportional" to B means A is just a constant times B: A= kB.
A is "inversely proportional" to B means A is a constant time 1/B or is a constant divided by B: A= k/B.
A is proportional to x2 and inversely proportional to (y-a)3 gives both: A= kx2/(y-a)3.
" given that A = 1 when x = 1 and y = 0" means that if you replace A in the formula with 1, x with 1, and y with 0, it is still true. That is:
1= k(12)/(0-a)3= -k/a3. You can use that to find k: k= -a3 (a was part of the original information but we are not given a specific value for a so all we can do is leave it in there.)
Putting that value for k back into the original formula,
A= -a3x2/(y-a)3.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
