Finding Acceleration Given Distance and Final Speed
To find the average acceleration of a baseball that accelerates over a distance of 3.5 meters from an initial speed of 0 m/s to a final speed of 41 m/s, the appropriate formula is derived from kinematics. The formula to use is \( a = \frac{(v_f^2 - v_i^2)}{2d} \), where \( v_f \) is the final speed, \( v_i \) is the initial speed, and \( d \) is the distance. Plugging in the values, the average acceleration can be calculated. The discussion emphasizes the importance of assuming constant acceleration for accurate results. Understanding the correct application of kinematic equations is crucial for solving such physics problems.
aprymek
1. A pitcher uses 3.5m to accelerate a baseball before release. Find the average acceleration of a ball starting at zero m/s and traveling 41m/s at release
Thanks in advance. I'm lost with what I need to do.
Welcome to PF!
Hi aprymek! Welcome to PF! :smile:
Assume a constant acceleration …
you know the initital and final speed, and the distance, so which formula should you use? :wink:
