Finding at which point multiplied numbers coalesce
  • Thread starter Thread starter ignorant2
    Numbers Point
The discussion focuses on finding the point at which two different numbers, such as 1.5 and 2, yield the same product when multiplied by certain integers. It emphasizes the concept of using rational numbers and forming equations to determine common multiples. The method involves setting up an equation based on the fractions representing the numbers and finding integer solutions for the multipliers. The smallest whole number can be identified by minimizing the multipliers used in the equation. Understanding this process requires knowledge of rational numbers and basic algebraic manipulation.
ignorant2
Hello!
This is not really a homework question, more of a question of what I should do for "homework", but I hope it is acceptable.
My question is regarding a method of finding at which point (if at all) two different numbers, when multiplied, reach the same number. For example, how could I find out that the first common whole number that numbers 1.5 and 2 both share is 6 - 1.5 multiplied by 4 and 2 multiplied by 3.
It should be obvious from my question and (lack of) terminology that I know almost nothing about mathematics. I am looking to learn more and will start a course soon, but in the meantime it would help a lot if someone could tell me what this type of method is called and what would be the prerequisite knowledge for understanding it.
Many thanks!
Start with your fraction 1.5 but with some unknown other number, x. Suppose they both divide a whole number, n. So n = some whole multiple, y, of 1.5. Is there anything you can deduce about y?
Let's assume that you are working with Rational numbers (those that can be represented as a fraction).
Your first number may have the form (a/b) and the second may have the form (c/d).
If your goal is to get to whole numbers, you should know that both numbers will only form whole numbers at multiples of b or d, respectively.
If one of your numbers is irrational, (no fractional representation), then you are out of luck.
I would look for solutions to the equation:
##bx(\frac ab )=dy(\frac cd )##.
You might be able to find a general rule for x and y. If you want to find the smallest whole number, you will then need to minimize your x and y.
In your example,
1.5 = 3/2
2 = 2/1
##2x(\frac 32 )=1y(\frac 21 )##
##3x=2y##
##\frac xy= \frac 23##
So x = 2 and y = 3 is a natural choice...your multipliers are 2x2 and 1x3, or 4 and 3 as you pointed out.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
