Finding B-Field Of Solenoid Slightly Off Axis?
The discussion focuses on calculating the magnetic field (B-field) of a solenoid positioned along the z-axis, particularly at slight deviations in the x and y directions. Participants highlight the complexity of this problem, which involves elliptic integrals and Taylor expansion techniques. A key point made is that the magnetic field inside a sufficiently long solenoid is homogeneous, negating the need for expansion in many cases. For finite solenoids, numerical integration techniques are necessary due to field divergence at the ends.
  • Understanding of magnetic fields and solenoid theory
  • Familiarity with elliptic integrals and their applications
  • Knowledge of Taylor series expansion and its mathematical implications
  • Experience with numerical integration techniques for field calculations
  • Study the application of elliptic integrals in electromagnetic theory
  • Learn about Taylor series expansion in the context of magnetic fields
  • Research numerical integration methods for calculating magnetic fields in finite solenoids
  • Examine the magnetic field equations for helix coils and their derivations
Physicists, electrical engineers, and students studying electromagnetism, particularly those interested in solenoid behavior and magnetic field calculations.
jasonpatel
If you have a solenoid positioned along the z axis...
...how would one find the b-field at slight deviations of x and y?
I have been googling for hours and can't find anything other than the fact that it is very difficult!
Thanks guys!
Science news on Phys.org
This is kind of a hard problem that involves elliptic integrals.
Here is paper that shows you how to do it .
http://ntrs.nasa.gov/search.jsp?R=19980227402
Also this might help.
http://www.netdenizen.com/emagnettest/offaxis/?offaxisloop
Interesting read, but extremely complicated! Haha, i was wondering if there was a way to taylor expand around the z axis with infinitely small deviations from the z axis (i.e. x+ε and y+ε)
Any thoughts?
Any thoughts?
What exactly do you want to expand?
Note that the magnetic field inside a sufficiently long solenoid is in fact homogeneous and there is no need to expand anything, Also the need for complicated math and numerical integration techniques arises even on axis for a short finite solenoid since the fields at the ends diverge.
http://en.wikipedia.org/wiki/Soleno...ctor_potential_for_finite_continuous_solenoid
Well, let me get a little more specific then.
My actual problem was to find the b-field of a helix coil along the axis of symmetry (z-axis), and I did. The B_x, B_y and B_z components are all a function of z and no other variables.
Then I was asked to find the b-field at very small deviations from the z-axis, x+ε and y+ε. I was also given the advice to do some "Taylor expansion of the field".
But i don't have a clue of how to do that! Any help??
Just to make things very clear I have attached a pdf of the integrals I will be computing. So, I am wondering if I should expand ∅ with a taylor expansion because of the assumption that displacements of ∅ will be very small i.e. (∅ + ε) and (∅ - ε)
I am hoping this expansion of ∅ will create a simple integral and the answer of which will give the b-field in terms of (x,y,z) with the assumption that displacements in the (x,y,z) will be very small (x+ε,y+ε,z+ε).
Does this sound reasonable or am I totally off? Also, how many terms in the taylor expansion should I keep?
