Finding Complement of a set with respect to space U
  • Thread starter Thread starter RJLiberator
    Set Space
The discussion focuses on finding the complement of a set C with respect to a space U in two scenarios. For the first case, the complement C' is correctly identified as the set of points where x^2 + y^2 < 1, clarifying that points on the boundary are not included in C'. In the second case, the challenge lies in distinguishing points within a square from those within a circle, ultimately leading to the conclusion that C' consists of points where x^2 + y^2 ≥ 2 and |x| + |y| ≤ 2. The participants emphasize the importance of visualizing the sets to better understand their relationships. The final answer for the second part is refined to accurately represent the desired area.
RJLiberator
Find the complement C' of the set C with respect to the space U if:
1. U = {(x,y,z) : x^2+y^2+z^2 ≤1}, C = {(x,y,z) : x^2+y^2+z^2 = 1}
2. U = {(x,y) : |x| + |y| ≤ 2}, C = {(x,y) : x^2 + y^2 < 2}
Definition of complement: The elements of the space that do not exist inside the set.
I wanted to reassure myself that I am doing things right.
For 1: My answer is C' = {(x,y,z): x^2+y^2+z^2 < 1}
However, why is this right? Couldn't I have (sqrt(1/3), sqrt(1/3), sqrt(1/3)) as (x,y,z) for the set C = 1, and then have C' = (sqrt(1/3), sqrt(1/3), 0) and then we have x and y equal in both C and C' ? Is my answer wrong or what am I missing in the understanding here?
For 2: x^2+y^2 < 2 is a circle with radius sqrt(2) where as |x| + |y| ≤ 2 is a square with corners on each x = - 2, x = 2, y= - 2, y = 2. So the area i am looking for is |x| + |y| - x^2 + y^2 ≤ 2.
But I am not sure how to put this into a final answer.
I can visualize it via the area, but it's hard to put this into an answer.
It does not matter if x and y are equal if not also z is equal. The elements of your set are combinations of three numbers. If those numbers are not all the same, the elements are not the same.
This is simply incorrect. You need to find out what points in the square are not points in the disk.
Likes RJLiberator
Thanks for your help. For part 1, I understand now and see why I was confused. Now I understand that I have the correct answer.
For part 2, after thinking about it, I also understand why my area-area part did not work out.
It's more to say:
(|x|+|y| ≤ 2) - (x^2+y^2 < 2) = the complement, but that's not a good answer. I need to find the points in the square that are not points in the disk as you stated.
I see that |x|+|y| = 2 is definitely in the complement.
What I am thinking here is
Answer: C' = {(x,y): sqrt(2) ≤ |x|+|y| ≤ 2}
This takes out the middle part and leaves the good ends. However, their seems to be an error in that sqrt(2) is just another square, but we want a circle.
Hint: You can put several conditions into the definition of the set.
Likes RJLiberator
@RJLiberator, if you haven't already done so, sketch a graph of the two sets. If you have done this, then disregard this advice.
Likes RJLiberator
Hm. I think I was making this harder then I needed to make it:
C' = {(x,y) : x^2+y^2 ≥ 2 and |x|+|y| ≤ 2 } This seems to get the correct area.
