Finding Coulomb's Force: Solved Problem w/ Explanation
  • Thread starter hastings
  • Tags
    Force
In summary, the conversation discusses finding the Coulomb's force between a long straight wire with a uniform linear density charge and a rectangular layer with a uniform superficial density charge. The suggested method is to find the electrostatic field from the charged wire and integrate it to calculate the force on an element of charge in the rectangular layer. The conversation also clarifies the use of different variable names and explains the reasoning behind using dx and b in the integration.
hastings
80
[SOLVED] finding coulmb's force
Problem:
A very long straight wire has a uniform linear density charge, λ (every dx, linear unit, has a λ charge). At a distance D, from the wire, there's a rectangular layer with length=a and height=b and a uniform superficial density charge, σ (every dS, superficial unit, has a σ charge). Find the electrostatic force between the 2 objects.
What I did:
(1)[tex] F=\int dF[/tex]
(2)[tex]dF=\frac{1}{4\pi \varepsilon_0} \frac{dq_1 \cdot dq_2}{x^2}[/tex]
(3)[tex] dq_1=\lambda dx[/tex]
(4)[tex] dq_2=\sigma dS \text{ (* When integrating dS becomes S=a $\cdot$ b)}[/tex]
(5)[tex]F=\int dF=\int_D^{D+a} \frac{1}{4\pi \varepsilon_0} \frac{(\lambda dx) \cdot \sigma dS }{x^2} = \frac{\lambda \sigma (a \cdot b)}{4\pi \varepsilon_0} \int_D^{D+a} \frac{1}{x^2}dx[/tex]
(6)[tex]=\frac{\lambda \sigma (a \cdot b)}{4\pi \varepsilon_0}(-\frac{1}{x})_D^{D+a}= \frac{\lambda \sigma (a \cdot b)}{4\pi \varepsilon_0} (\frac{1}{D}-\frac{1}{D+a}) =\frac{\lambda \sigma (a \cdot b)}{4\pi \varepsilon_0}\frac{a}{D(D+a)}[/tex]
(7)[tex]=\frac{\lambda \sigma (a^2 b)}{4\pi \varepsilon_0 \ D(D+a)} [/tex]
Is my reasoning right? Or, where did I mistake? Please check out the little drawing in the attachment.
Thank you.
can anyone help. tell me if it's right or wrong.
No, it's not right.
Don't try to integrate Coulomb's law directly--that's the hard way. (If you do choose that route, you must do it correctly. For one, you must integrate along the full length of the wire and the full area of the rectangle: every element of charge in the wire exerts a force on every element of charge in the rectangle.)
Instead, find the field from the charged wire and figure out the force that that field exerts on an element of charge in your rectangular layer. Then integrate that.
if I'm not mistaken, the Electrical field at a distance D from the long straight wire should be this,
(2.1) [tex]E=\frac{\lambda}{2\pi\varepsilon_0D}[/tex]
(2.2) Since [tex]dF=E\cdot dq_2 \text{ and } dq_2=\sigma [/tex],
(2.3) [tex]F=\int dF=\int E dq_2=\int \frac{\lambda}{2\pi\varepsilon_0D}\sigma[/tex]
ok? but when I integrate, I should have something like "dx". Also (a*b) should pop up somewhere. Can't figure out these last two things.
Could it instead be this?
(3.1) [tex]F=\int dF=\int E dq_2=\int \frac{\lambda}{2\pi\varepsilon_0D}dq_2=\frac{\lambda}{2\pi\varepsilon_0D}q_2=[/tex]
[tex]q_2=\sigma(a\cdot b) \longrightarrow \ F=\frac{\lambda}{2\pi\varepsilon_0D} \sigma(a\cdot b)[/tex]
Right. But since D is already used to represent a fixed distance in your problem, better use a variable name such as x. Using x to represent distance from the wire, the field is:
[tex]E=\frac{\lambda}{2\pi\epsilon_0 x}[/tex]
[tex]dq = \sigma dA = \sigma b dx[/tex]
The "dx" comes from expressing the charge element in terms of area. The "b" factor comes in when describing the area in terms of length and width. (See what I did directly above.) The "a" factor will come in after you do your integration.
[tex]F=\int dF=\int E dq_2=\int_D^{D+a} \frac{\lambda}{2\pi\varepsilon_0x}\sigma b dx[/tex]
is it like this?
When you say [tex]dq = \sigma dA = \sigma b dx[/tex]
is it like you're dividing the layer into thin vertical, rectangular-shaped strips with height=b, and length=dx?
is it like this?
Yes.
Yes. It makes sense to do it that way, since the field is the same everywhere within such a thin strip.
You could say:
[tex]dq = \sigma dA = \sigma dy dx[/tex]
But then you'd just have to integrate with respect to y as well. (You'll get the same answer, of course, since the integral of dy will equal b.)
Also, regarding your diagram: Once source of confusion is that you chose the same name (x) for two unrelated things. On the left, you use x to represent position along the line of charge. But you also use x to represent distance from the line charge. Use different variable names!
Got it. Thank you for all your help.
1. What is Coulomb's force?
Coulomb's force is an electrostatic force that describes the attraction or repulsion between two charged particles. It is similar to the force of gravity, but instead of mass, it is determined by the magnitude of the charges and the distance between them.
2. How is Coulomb's force calculated?
Coulomb's force is calculated using the formula F = k(q1q2)/r^2, where F is the force, k is the Coulomb constant (9x10^9 Nm^2/C^2), q1 and q2 are the magnitudes of the charges, and r is the distance between the charges.
3. What is the significance of Coulomb's force in physics?
Coulomb's force is a fundamental force in physics, as it describes the interaction between charged particles and is crucial in understanding the behavior of electricity and magnetism. It is also essential in fields such as electronics, engineering, and chemistry.
4. Can Coulomb's force be repulsive?
Yes, Coulomb's force can be either attractive or repulsive, depending on the charges of the particles. Like charges (both positive or both negative) will repel each other, while opposite charges (positive and negative) will attract.
5. How is Coulomb's force related to the principle of superposition?
The principle of superposition states that the total force acting on a particle is the sum of all individual forces acting on it. Coulomb's force follows this principle, as the force between two charged particles is the vector sum of the forces between each pair of charges.
