Finding Density & Diameter at Inlet & Outlet
The discussion focuses on calculating the density at the inlet and outlet and the outlet diameter for a turbine system. Density can be determined using the formula pressure divided by the product of the gas constant and temperature. There is confusion regarding the inlet and outlet pressures, with the problem indicating 45 psi at the outlet and 160 psi at the inlet, leading to questions about the accuracy of the diagram. Participants agree that heat loss does not affect the required values, and conservation of mass principles apply to determine the exit area. Ultimately, calculations yield an outlet diameter of approximately 0.453 ft, despite initial discrepancies in expected area sizes.
pyroknife
I attached the file.
I just wanted to clarify something.
All i need to find is the density @ inlet&outlet and the diameter at the outlet.
The heat loss they have shown has no impact on the values that were asked for right?
density can be found by pressure/(RT) where R=gas constant and T=temperature
And the diameter can be found by setting the mass flow at the inlet = mass flow at the outlet.
The problem states the inlet pressure is 45 psi. But the diagram shows 160 psi at inlet. The 45 psi is shown at the outlet. Something is amiss.
But to answer your question, if you know P and T, you can determine density. Knowing that you know the mass flow. The heat loss has no impact on the values asked. Conservation of mass will determine exit area.
Yeah I noticed that typo too. The prof said to assume it is 160 psi. Okay I thought so.
Basically my calculations for the density was pressure/(RT)
Where R=gas constant of air and T=temperature in rankineI just said set (density at inlet)*(Velocity at inlet)*(Area of inlet)=(density at outlet)*(Velocity at outlet)*(Area of outlet) and solved for the exit area.
But jst out of curiosity, all turbines have circular cross sections right?
A round shape is the easiest to machine and therefore costs less. Exhaust pipes are subject to thermal stresses due to piping wanting to expand radially and axially at startup. If it were square or had any corners, you would have built in 'stress risers' that would make it more prone to failure. Round is best for any number of reasons.
Oh okay, I just solved the problem, but something weird happened.
The way the picture is drawn, the outlet area should be bigger, but the area I got issmaller than the inlet.
Yes, I also end up with a larger exit area. But rho*A*V = constant. Working fluid is air. If you know pressure and temperature, you then know density. The trapezoid symbols used for compressors and turbines in thermo texts are meant to infer the working fluid is compressed or expanded. The numbers in this problem are strange.
Thanks. did you get diameter = 0.453 ft?
I talked to a friend. He says turbines are supposed to have a smaller outlet area than inlet. And that the figure is drawn like a diffuser instead of a tirbine.
I do not calculate 0.453 ft^2. I get a little over 23 in^2 which is 0.16 ft^2.
First I calculated the two densities
At 1: density=P1/(RT1)
P1=(160 lb/in^2 * 12in^2 / 1ft^2)
R=(1716 ft*lbf/(slug*R)
T1=320+460 R
P1= .0172 slug/ft^3
P2=45 lb/in^2 * 12in^2/1ft^2
R=1716 ftlb/(slugR)
T2=50+460 R
Density 2=.0074 slug/ft^3
COnservation of mass:
(.0172)(30/144 ft^2)(100ft/s)=.0072 slug/ft^3 * 300 ft/s * A2
A2=.1614 ft^2
Diameter=.453 ft
Crap! I just wrote this all out for no reason. I meant I got diameter=.453 ft. I got Area=.16 ft^2 as well.
