Finding Derivatives: h(2)=4, h'(2)=-3, d/dx(h(x)/x)|x=2
  • Thread starter Thread starter Joyci116
    Derivative
The discussion revolves around finding the derivative of the function h(x)/x at the point where x=2, given that h(2)=4 and h'(2)=-3. Participants are exploring the application of derivative rules, particularly the quotient rule, in this context.
  • Participants express confusion about the notation and the meaning of the derivative of h(x)/x. There are attempts to clarify the use of the quotient rule and to evaluate the derivative at x=2. Some participants question the assumptions made about h(x) based on its value at a specific point.
The discussion is ongoing, with participants providing guidance on how to approach the problem using the quotient rule. There is a mix of interpretations and attempts to simplify the expression, but no consensus has been reached on the correct evaluation or method.
Participants are working under the constraints of the problem statement, which provides specific values for h(2) and h'(2) but does not define h(x) in general. There is also uncertainty regarding the application of derivative rules and the implications of evaluating at a specific point.
Joyci116
If h(2)=4 and h'(2)=-3, find
[tex]\left.\frac{d}{dx}\frac{h(x)}{x}\right|_{x=2}[/tex]
n^n-1 (power rule)
I don't know how to get this started. It seems like I am having trouble with derivatives. I can do simple derivatives with the power rule, product rule, and quotient rule, but I do not know what the line on the right means, nor do I understand what the d/dx times the quantity of h(x)/x means.
It means find the derivative of f(x)/x when (or, at the point where) x equals 2.
Joyci116 said:
If h(2)=4 and h'(2)=-3, find [itex]\displaystyle \left[\frac{d}{dx}\left(\frac{h(x)}{x}\right) \right|_{x=2}[/itex]
n^n-1 (power rule)
d/dx times the quantity of h(x)/x means: the derivative of h(x)/x
the line on the right means: evaluate the derivative at x = 2
SO the derivative would be -3/4?
No. Are you using the quotient rule?
Helps to show your work.
Um, h(x)=4, because x=2 so h(2)=4; x=2, so I get 1/2. But you don't understand how you would the the quotient rule using that value. There is the product rule if you rearrange the formula to 1(2)^-1
I'm sorry, I'm a little confused.
(Don't put 2 in for x just yet.)
What is the derivative of [itex]\displaystyle \frac{h(x)}{x}[/itex] , using the quotient rule?
If that doesn't make sense, then what is the derivative of [itex]\displaystyle \frac{h(x)}{g(x)}\,?[/itex]
Joyci116 said:
Um, h(x)=4,
No, you can't say this. You don't know what h(x) is, only what its value is at a particular x value.
Forget the numbers for now.[/color]
1. Find the derivative of h(x)/x. I would use the quotient rule.
2. Evaluate the derivative you found in #1 at x = 2.
[itex]\frac{x[h'(x)]-h(x)x'}{x^{2}}[/itex]
What's x' ?
Simplify what you have.
Then evaluate everything at x = 2.
x=2
[2(-3)-4(0)]/2^2 =-3/2
Not quite, but you're close. What's x'? (It's not 0.)
  • · Replies 24 ·
  • · Replies 25 ·
