Finding dipole moment / Electric Field Problem
14 replies · 3K views · last reply
puggleboy
Problem 3 from the attached photo
p = qd
I know the magnitude of the dipole moment is p = qd, where d is the distance between the 2 oppositely charged particles. I know the direction of the dipole moment vector is from - to +. My first thought is there's no charge separation, and hence a dipole moment equals zero. Something tells me this isn't the case.
  • Handwritten problem 3 and problem 4 from a physics worksheet, with a diagram of a circle labeled +Q at top and -Q at bottom, showing two touching half-rings of radius R with a radius line marked R.
I don't know why you think there is no charge separation. Some charges are R√2 from the nearest opposite charge. Only where the two semicircles meet is there no separation.
Something like p = ∫dp = ∫∫dq⋅dr, where 0 ≤ r ≤ R ?
The charges are along arcs, not distributed over semicircular areas, so I don't see how you get a double integral.
What if I setup like this (attached), using:
p = ∫dp = q∫2y = 2q∫(R2-x2)0.5dx from R to -R? Don't I need to differentialize Q somehow?
  • Hand-drawn diagram of a circle with horizontal and vertical axes through its centre; a green triangle has two sides labelled R from the centre and a vertical chord labelled y and y at its right edge.
That integral should work, but you will find it easier in polar coordinates. I don't know what you mean by "differentialize Q".
So, using...
Hand-drawn diagram of a ring on x and y axes, with a dashed line through the centre joining two green dots on opposite sides, labelled +dq at upper right and -dq at lower left.
...would we use d = charge separation = 2R, not d=R?
So, p = ∫dp = ∫d(dq) = ∫(2R)dq = ∫(2R)[λRdθ]
Where λ=Q/s, so Q = λs, or dq=λds=λRdθ, resulting in...
So, p = 2λR2∫dθ from pi to -pi?
This isn't feeling right since nothing is mentioned about charge density...??
So, using...
No, the integral you have now won't work. The dipole moment is a vector. Integration is a sum, so when you integrate vectors you need that sum to reflect vector addition. Your diagram above pairs charges in such a way that the dipoles willpoint in different directions.
Your previous way of pairing them was fine, and so was the integral you wrote down. You just need to rewrite that integral in polar form.
That was my attempt at re-writing in polar form... which apparently is incorrect. I'm staring at...
Hand-drawn diagram of a magenta circle centred on the origin of crossed black axes, with a dark green isosceles triangle inside: two sides from the centre to points on the circle labelled R, and a vertical chord on the right labelled y.
If I try x=Rcosθ, y=Rsinθ
  1. p = ∫dp
  2. = ∫(Q)(2y)
  3. = 2Q∫Rsinθdθ
  4. = -2QRcosθ
  5. eval'd from 0 to pi?
For #2, don't I need a variable of integration? If I use dy, rather than y, I'd get a sine term in #4, which would result in an answer of zero - which I'm pretty sure isn't correct?
Also, still doesn't seem like I'm capturing the charge, Q, correctly via this method?
ρρ
  1. p = ∫dp
  2. = ∫(Q)(2y)
  3. = 2Q∫Rsinθdθ
  4. = -2QRcosθ
In line 2, Q is the charge on a small element of arc, ρRdθ.
In line 3, you have correctly left the dθ inside the integral, so the Q outside is now ρR.
Other than that, your steps 1 to 5 are correct. It does not give zero.
okay - thank you *very* much for all your help!
You are welcome. What was your final answer? Bear in mind that you were given the total charge on each arc, not the charge density.
Right. I assume I'd use:
  1. ρ= Q/s
  2. = Q/(2πR)/2, or
  3. ρ = Q/(πR)?
