Finding electric potential of an infinite line charge at z axis
  • Thread starter Thread starter physics1000
    Electric potential
The discussion revolves around finding the electric potential of an infinite line charge located along the z-axis, specifically at the point defined by coordinates (x, y). The original poster indicates that the potential at the origin is set to zero, and expresses difficulty in integrating to find the potential at other points due to the infinite nature of the line charge.
  • Exploratory, Assumption checking
  • Participants discuss the use of Gauss' law and the implications of symmetry in the problem. The original poster attempts to set up an integral for the potential but struggles with the integration limits and the requirement to express the potential solely in terms of x and y, without involving z.
Some participants suggest alternative approaches to the integration limits, questioning why the original poster cannot use z in their calculations. Others seek clarification on the setup of the problem, particularly regarding the placement of the line charge and the coordinates involved.
The original poster emphasizes that the problem constraints require them to find the potential without incorporating the z-coordinate, which adds to their confusion. There is also mention of a diagram that may clarify the configuration of the line charge.
  • #61
Orodruin said:
Still impossible to see what is written in text. This is how it looks:
For the future, please learn to use the LaTeX features of the forum.As I told you several times, this was never a problem. Your problem was not shifting the potential to keep the zero level at the correct place. The point-particle potential you should be using was
G(\vec r, \vec r') = \frac{1}{4\pi \epsilon_0} \left( \frac{1}{|\vec r - \vec r'|} - \frac{1}{|\vec r'|}\right)
This has the same derivatives with respect to the unprimed coordinates as the typical point-particle potential (the first term) but is constructed to have the zero-level at the origin ##\vec r = 0##. The integral will converge without issues.
Alternatively you can just take the integral from ##-Z## to ##Z##, subtract the potential at the origin after, and then let ##Z \to \infty##.
Oh sorry, I know how to latex, I did it before at this post.
I will write it now:
##\vec{r\:\:}=\left(x,\:y,\:z\right)\:##
##\:\vec{r'\:\:}=\left(a,\:0,\:z'\right)##
##\vec{R_{\:\:}}\:=\:\left(x-a,\:y,\:-z'\right)##
##\:\left|\vec{R\:}\right|=\:\left(\left(x-a\right)^2+y^2+\left(z'\right)^2\right)^{\frac{1}{2}}##
##\lambda \left(\vec{r'\:}\right)=\lambda _0##
##\Phi \left(\vec{r'\:}\right)=\frac{1}{4\pi \epsilon _0}\int _{-\infty }^{+\infty }\frac{\lambda _0}{\left(\left(x-a\right)^2+y^2+\left(z'\right)^2\right)^{\frac{1}{2}}}\:dz'##
Not Good, so we find Electric field
##\:\:\:\:\:\vec{E}\left(\vec{r\:}\right)=\frac{\lambda _0}{4\pi \epsilon _0}\int _{-\infty \:}^{+\infty \:}\frac{\lambda \:_0}{\left(\left(x-a\right)^2+y^2+\left(z'\right)^2\right)^{\frac{3}{2}}}\:dz'\:=\frac{\lambda _0}{2\pi \epsilon _0}\left[\frac{1}{\left(x-a\right)^2+y^2}\right]\hat{r\:}##
And then
##\Phi \left(\vec{r'\:}\right)=-\frac{\lambda _0}{2\pi \epsilon _0}\int _a^{\sqrt{\left(x-a\right)^2+y^2}}\frac{1}{r}dr\:=\frac{-\lambda _0}{2\pi \epsilon _0}ln\left(\frac{\sqrt{\left(x-a\right)^2+y^2}}{a}\right)##
And about your idea, I dont really understand how it shifted it to zero? and what it means by that.
  • #62
The (unit charge) point particle potential for a particle in ##\vec r'##, which is zero at infinity is on the form:
G_0(\vec r, \vec r') = \frac{1}{4\pi\epsilon_0} \frac{1}{|\vec r - \vec r'|}.
If you just integrate this with the line charge, you will get something divergent. Even if you did not, you would get something that is typically not zero in ##\vec r = 0##. In order to get something that is zero in ##\vec r = 0##, you need to add a constant (in ##\vec r##) to this potential. This is what we mean by a shifted potential. (scalar) Potentials are only defined up to a constant so this is perfectly fine. Integrating a potential that is always zero in ##\vec r = 0## will of course result in a potential that is also zero at that point - satisfying that part of your problem. So, the only question is which constant to shift the potential by. This is also not hard to find out because you want your ##G(\vec r, \vec r')## to be zero in ##\vec r = 0##, so you put ##G(\vec r, \vec r') = G_0(\vec r, \vec r') + g(\vec r')## where ##g(\vec r')## can possibly be a function of ##\vec r'## because the only requirement is that it does not depend on ##\vec r##. By inserting the requirement that ##G(0, \vec r') = 0##, we easily find that
G(0,\vec r') = G_0(0, \vec r') + g(\vec r') = 0 \qquad \Longrightarrow \qquad
g(\vec r') = - G_0(0,\vec r') = - \frac{1}{4\pi\epsilon_0 |\vec r'|}.
Integrating over the entire line charge, in general we will have
\Phi(\vec r) = \int_{-\infty}^\infty G(\vec r, z' \vec e_z + a \vec e_x) \lambda\, dz'
which is a perfectly well converging integral.
  • #63
Oh I see, it is confusing, but I will try this out of curiosity :)
Thanks!
And thanks again for explaining it to me, and elaborating on it.
  • #64
Thanks!
Which part do you find confusing?
  • #65
The fact that I have to find a function such that the potential will be zero and the general thingy at the end.
But I just realized it is general, so I dont really have to understand that general integral, only to understand what to do.
And I just understood I think, I will try tomorrow this way and update if needed.
  • · Replies 17 ·
  • · Replies 18 ·
