Finding Inductance and Mutual Inductance
The discussion revolves around calculating inductance and mutual inductance for multiple conductors, particularly in the context of finite element analysis (FEA) simulations. Participants explore theoretical frameworks, mathematical formulations, and practical considerations related to inductance in configurations with two or more conductors, including the implications of current direction on mutual inductance.
  • One participant is using FEA simulation to solve for inductance and seeks to expand the inductance equation for multiple conductors beyond two.
  • Another participant suggests that the inductance of each element is the sum of its self-inductance and the mutual inductance with all other elements, proposing a triangular matrix approach for calculations.
  • A participant using Ansys Maxwell expresses uncertainty about calculating inductance from available parameters and wishes to relate it back to Maxwell's equations.
  • Discussion includes the idea that for four parallel conductors with alternating current directions, mutual inductance effects may be subtractive, leading to a proposed formula for equivalent inductance.
  • Concerns are raised about the possibility of achieving negative inductance with increasing numbers of conductors, questioning the behavior of mutual inductance as the number of conductors increases.
  • Another participant introduces the concept of using magnetic field energy to calculate self-inductance and expresses uncertainty about applying this to mutual inductance.
  • One participant emphasizes the importance of specifying the spatial distribution of conductors and suggests that equal spacing may not be feasible in three-dimensional configurations.
  • Another participant challenges the logic of equal spacing among multiple parallel elements and discusses the implications of circuit definition on inductance calculations.
Participants express differing views on the implications of mutual inductance in configurations with multiple conductors, particularly regarding the potential for negative inductance. There is no consensus on the correct approach to calculating inductance in these scenarios, and several competing models and interpretations are presented.
Limitations include assumptions about conductor spacing and geometry, as well as unresolved mathematical steps in the inductance calculations. The discussion highlights the complexity of defining circuits and the interactions between multiple conductors.
Ntip
TL;DR
I am trying to solve for inductance through FEA simulation. I and doing eddy current simulations so I can have H field, B field, and current density available
I am trying to solve for inductance through FEA simulation. I and doing eddy current simulations so I can have H field, B field, and current density available.
I am also trying to find an equation for the equivalent inductance with multiple conductors. I know that for two conductors it is Leq = L1 + L2 +/- M12 +M21. If L1=L2 and M12=M12, it simplifies to L=2L1+/-2M12. I'm trying to find how to expand this out to maybe 4 conductors.
Well, that is interesting. What software are you using ?
Do you have a specific question ?
The inductance of each element is the sum of it's self inductance + the mutual inductance with all other elements of the circuit conductor. Since the M of segment a with b is the same as b with a, you can generate a triangular matrix, then double it.
Only two element interactions are required to compute the matrix.
The equations needed for computation of M are given in chapters 3 to 7 of the book by Frederick W. Grover. (1973) "Inductance Calculations. Working formulas and tables". Chapter 4, is only 3 pages. It describes the method of analysis and matrix construction.
You are in for plenty of 2D or 3D vector computations, and some Atanh() functions for the wires at odd angles.
I'm using Ansys Maxwell 3D. I can also do it in Ansys Maxwell 2D to eliminate the thickness component for simplicity.
My question is more in general I guess. I'm not really to sure how to calculate inductance from the parameters that I have. Ideally, I would like to tie the inductance calculation back to Maxwells equations. I've been looking online and haven't found it which surprised me. I have the material properties, current I, current density J, magnetic field H field, and magnetic flux density B.
As far as the mutual inductance...let's look at the case of 4 parallel conductors and say that their current directions alternate. In this way, the effects of their mutual inductance should be subtractive. If my understand is correct, it is subtractive because the magnetic field from the adjacent conductor is in the opposite direction when is passes through the other conductor and by vector addition the B-field inside of the conductor is decreases which decreases the tendency to opposite the change in current in the conductor (inductance). So if we have four parallel conductors with current in the opposite directions, the equivalent inductance would be
L1 + L2 + L3 + L4 - M12 - M21 - M23 - M32 - M34 - M43
If we assume all geometries between the conductors are the same, the coupling M12, M21, M23, M32, M34, M43 would all be the same. so if L = L1 = L2 = L3 = L4, and M = M12, we would have
Leq = 4*L -6*M.
That doesn't make sense to me because does that it makes it look like if I put say 1,000,000 in parallel, I could possibly get a negative inductance. Of course 1,000,000 is just an exaggeration to show my point but still. Any suggestions?
Ntip said:
So if we have four parallel conductors with current in the opposite directions,...
You appear to be describing two return circuits or transmission lines.
Reduce the circuit to many straight elements, all vectors and all pointing along the circuit in the direction of reference current flow. For a return circuit, the parallel elements will be running in opposite directions, so the sign of M and the induced voltage will also be reversed.
Where the two currents flow in opposite directions, the magnetic fields will sum in the area between the wires, while they tend to cancel outside. Where currents are in the same direction, the magnetic fields will tend to cancel in the area between the wires while they sum outside.
Yes, I understand that the induced voltage is reversed which is what leads to a negative coupling (-M). What I'm saying is that in the case of 2 conductors in the case of subtractive mutual inductance, it makes sense that the equivalent inductance is 2L-2M or n(L+M) for n=2. But if you have 4 conductors it turns out to be 4L-6M. Six conductors would be 6L- 6M - M45 - M54 - M56 - M65 = 6L - 10M. The equation seems to equate to n(L-M)-(n-2)M for even numbers of n. So if n is really large, you would end up negative inductance which wouldn't be the case. So I'm wondering what's really happening with the B field inside of the conductors. It seems that even if the magnitude of current in each conductor is the same, the magnitude of mutual inductance M must be reduced for n>2 compared to n=2 so that Leq does will always be positive.
If you consider filaments, you eliminate internal inductance.
It is insufficient to simply specify parallel.
You must also specify distribution of elements in space as GMD.
N conductors can pass through a fixed sectional area of a ;
or can be alternated with separation d across a flat plane of width d·(n-1) .
If you present a fixed voltage step of V to your model, and then measure di/dt ;
you can compute L = V · dt / di
I think the easiest way to calculate the self inductance is to use the magnetic field energy. If you have a single conductor, you can solve for the B-field everywhere. Then the total magnetic field energy is [itex]E = \int \frac{B^2}{2 \mu_0} dV[/itex], where the integral is over all space. Then you can calculate the inductance from [itex]E = \frac{1}{2}L I^2[/itex]. When you have multiple conductors, you can calculate the individual inductance of each conductor separately. I'm not sure how you would go about calculating the mutual inductance in this way.
Ok so yes in additional to the conductor geometries being the same, separation is also the same which is what would allow M12=M21=M23=... So let's say these are all parallel conductors with alternating current direction, Leq would normally be Leq=L/n where n is the number of conductors. Considering the subtractive mutual inductance, I would get $$ \frac {(L-M)-(n-2)M} {n}$$.
That's the equation that I get doing 4 and 6 conductors anyway but it wouldn't hold as n get's really large as that would lead to a negative. If the convention that I mentioned in the posts above to determine Leq is correct, then it seems like M must get smaller to prevent Leq from going negative in the case where n is really large. Am I missing something with my logic? Or is it unclear what I'm trying to say/ask?
You are missing something in your logic, and failing to clearly specify the circuit.
You cannot have equal spacing between 4 or more parallel elements, it is geometrically impossible beyond the equilateral triangle. Your separations between elements do not hold in 3D space.
How many circuits do you have? The elements that are parallel are only the currents. Until you connect the ends to define one circuit with two terminals, the voltage summation is undefined.
A folded wire makes two close parallel elements. That has low inductance, NOT negative inductance. If the fields of the elements cancel, there is no field and so, no inductance.
  • · Replies 16 ·
